Went to upload a file and Octoprint hung at the Saving portion of the upload. Restarted the server and now have lost all files in Octoprint and can not upload files or create directories
Rebooted a number of time
Ran in safe mode, while it was loading I could see my file list was back, and some test directories that I created when it was not working were visible. But then it asked me to refresh my browser and after doing this the file list was again blank
Complete Logs
`octoprint.log`, `serial.log` or output on terminal tab *at a minimum*, browser error console if UI issue ... **no logs, no support!** Not log excerpts, *complete* logs.)
2020-10-09 15:51:26,525 - octoprint - ERROR - Exception on /api/files [GET]
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 2447, in wsgi_app
response = self.full_dispatch_request()
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1952, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1821, in handle_user_exception
reraise(exc_type, exc_value, tb)
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1950, in full_dispatch_request
rv = self.dispatch_request()
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1936, in dispatch_request
return self.view_functions[rule.endpoint](**req.view_args)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/vendor/flask_principal.py", line 199, in _decorated
rv = f(*args, **kw)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/util/flask.py", line 1116, in decorated_function
response = f(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/api/files.py", line 130, in readGcodeFiles
return jsonify(files=files, free=usage.free, total=usage.total)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/util/flask.py", line 266, in fixed_jsonify
dumps(data, indent=indent, separators=separators, allow_nan=False) + '\n',
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/json/__init__.py", line 211, in dumps
rv = _json.dumps(obj, **kwargs)
File "/usr/lib/python2.7/json/__init__.py", line 251, in dumps
sort_keys=sort_keys, **kw).encode(obj)
File "/usr/lib/python2.7/json/encoder.py", line 209, in encode
chunks = list(chunks)
File "/usr/lib/python2.7/json/encoder.py", line 434, in _iterencode
for chunk in _iterencode_dict(o, _current_indent_level):
File "/usr/lib/python2.7/json/encoder.py", line 408, in _iterencode_dict
for chunk in chunks:
File "/usr/lib/python2.7/json/encoder.py", line 332, in _iterencode_list
File "/usr/lib/python2.7/json/encoder.py", line 400, in _iterencode_dict
yield _floatstr(value)
File "/usr/lib/python2.7/json/encoder.py", line 254, in floatstr
repr(o))
ValueError: Out of range float values are not JSON compliant: inf
2020-10-09 15:51:26,543 - tornado.access - ERROR - 500 GET /api/files?recursive=true (::ffff:10.0.1.1) 967.23ms
Its been working great for years. Something must have got corrupted when I uploaded a recent file. It seems to be a corrupt inf file from looking at the log, but it does not say the name and location of the file. So not sure had to manual edit and fix.
