Ok. I've done some testing. My apologies for this wall of text, but this is troubleshooting.
I think the root question is how to get OctoLapse to trigger before the print actually starts.
By enabling the serial log in Octoprint I was able to see what was sent and received between my octopi and MK3S. Of note, I saw that the line G4 P0@OCTOLAPSE TAKE-SNAPSHOT was sent in full to the MK3S. There wasn't an error code from the MK3S so it is good to see that it was silently ignored. But there was no indication in the serial log that any instructions were sent to the MK3S to move the extruder to the snapshot position. So I stopped that, just using the plane-jane trigger of @OCTOLAPSE TAKE-SNAPSHOT. I wrapped my trigger lines with M117 lines to make it easer to find in both the saved gcode and the serial log. To the Start G-code in PrusaSlicer I added 6 octolapse snapshots in different places, including at the very end, written as:
M117 Start G-code Octosnap 1 of 6
M400 ; Wait for buffer to empty
M117 End Octosnap
To the End G-code I added 2 octolapse snapshots written as:
M117 End G-code Octosnap 1 of 2
M117 End Octosnap
To the Before layer change G-code I added this:
M117 Before layer [layer_z] change G-code Octosnap
M117 End Octosnap
And to the After layer change G-code I added this:
M117 After layer [layer_z] change G-code Octosnap
M117 End Octosnap
Reviewing the serial log I found that not only were all the 6 snapshot commands in the start g-code ignored (no extra octolapse commands added) but the two layer change snapshot commands before the start of the print were also ignored.
Here is the full serial log for my last print (clipped from the serial log in the systeminfo bundle at the end of this post):
OctoSnap_Test_serial.log (296.3 KB)
Here are all the OctoLapse trigger sections followed by the section of the serial log inline. My OctoLapse stabilization configuration is the default back right which translated to X247.500 Y207.870. My OctoLapse trigger is the default smart-gcode trigger.
M117 End Octosnap
2021-07-23 17:27:13,122 - Send: N30 M117 Start G-code Octosnap 1 of 6*5
2021-07-23 17:27:13,136 - Recv: LCD status changed
2021-07-23 17:27:13,137 - Recv: ok
2021-07-23 17:27:13,139 - Send: N31 M400*21
2021-07-23 17:27:13,144 - Recv: ok
2021-07-23 17:27:13,147 - Send: N32 M117 End Octosnap*97
M117 Start G-code Octosnap 2 of 6
M117 End Octosnap
2021-07-23 17:27:44,436 - Send: N40 M117 Start G-code Octosnap 2 of 6*1
2021-07-23 17:27:44,456 - Recv: LCD status changed
2021-07-23 17:27:44,458 - Recv: ok
2021-07-23 17:27:44,463 - Send: N41 M400*18
2021-07-23 17:27:44,484 - Recv: ok
2021-07-23 17:27:44,495 - Send: N42 M117 End Octosnap*102
M117 Start G-code Octosnap 3 of 6
M117 End Octosnap
2021-07-23 17:29:52,931 - Send: N56 M117 Start G-code Octosnap 3 of 6*7
2021-07-23 17:29:52,953 - Recv: LCD status changed
2021-07-23 17:29:52,954 - Recv: ok
2021-07-23 17:29:52,978 - Send: N57 M400*21
2021-07-23 17:29:53,217 - Recv: T:159.9 /160.0 B:65.8 /65.0 T0:159.9 /160.0 @:27 B@:0 P:39.2 A:37.6
2021-07-23 17:29:53,773 - Recv: ok
2021-07-23 17:29:53,790 - Send: N58 M117 End Octosnap*109
M117 Start G-code Octosnap 4 of 6
M117 End Octosnap
2021-07-23 17:31:03,657 - Send: N65 M117 Start G-code Octosnap 4 of 6*0
2021-07-23 17:31:03,667 - Recv: LCD status changed
2021-07-23 17:31:03,668 - Recv: ok
2021-07-23 17:31:03,670 - Send: N66 M400*23
2021-07-23 17:31:03,675 - Recv: ok
2021-07-23 17:31:03,678 - Send: N67 M117 End Octosnap*97
M117 Start G-code Octosnap 5 of 6
M117 End Octosnap
2021-07-23 17:31:04,343 - Send: N93 M117 Start G-code Octosnap 5 of 6*8
2021-07-23 17:31:04,355 - Recv: LCD status changed
2021-07-23 17:31:04,356 - Recv: ok
2021-07-23 17:31:04,358 - Send: N94 M400*26
2021-07-23 17:31:04,708 - Recv: T:226.1 /225.0 B:65.0 /65.0 T0:226.1 /225.0 @:43 B@:4 P:41.2 A:37.3
2021-07-23 17:31:06,542 - Recv: echo:busy: processing
2021-07-23 17:31:06,805 - Recv: T:226.2 /225.0 B:65.1 /65.0 T0:226.2 /225.0 @:37 B@:0 P:41.3 A:37.5
2021-07-23 17:31:08,636 - Recv: echo:busy: processing
2021-07-23 17:31:08,902 - Recv: T:225.4 /225.0 B:65.2 /65.0 T0:225.4 /225.0 @:57 B@:0 P:41.5 A:37.3
2021-07-23 17:31:10,737 - Recv: echo:busy: processing
2021-07-23 17:31:10,938 - Recv: ok
2021-07-23 17:31:10,944 - Recv: T:225.2 /225.0 B:65.2 /65.0 T0:225.2 /225.0 @:60 B@:5 P:41.6 A:37.8
2021-07-23 17:31:10,971 - Send: N95 M117 End Octosnap*108
M117 Start G-code Octosnap 6 of 6
M117 End Octosnap
2021-07-23 17:31:11,036 - Send: N99 M117 Start G-code Octosnap 6 of 6*1
2021-07-23 17:31:11,045 - Recv: LCD status changed
2021-07-23 17:31:11,046 - Recv: ok
2021-07-23 17:31:11,048 - Send: N100 M400*38
2021-07-23 17:31:11,054 - Recv: ok
2021-07-23 17:31:11,077 - Send: N101 M117 End Octosnap*80
M117 Before layer 0.2 change G-code Octosnap
M117 End Octosnap
2021-07-23 17:31:11,174 - Send: N108 M117 Before layer 0.2 change G-code Octosnap*1
2021-07-23 17:31:11,184 - Recv: LCD status changed
2021-07-23 17:31:11,184 - Recv: ok
2021-07-23 17:31:11,187 - Send: N109 M400*47
2021-07-23 17:31:11,192 - Recv: ok
2021-07-23 17:31:11,222 - Send: N110 M117 End Octosnap*80
M117 After layer 0.2 change G-code Octosnap
M117 End Octosnap
2021-07-23 17:31:11,311 - Send: N114 M117 After layer 0.2 change G-code Octosnap*113
2021-07-23 17:31:11,319 - Recv: LCD status changed
2021-07-23 17:31:11,321 - Recv: ok
2021-07-23 17:31:11,325 - Send: N115 M400*34
2021-07-23 17:31:11,333 - Recv: ok
2021-07-23 17:31:11,372 - Send: N116 M117 End Octosnap*86
M117 Before layer 0.4 change G-code Octosnap
M117 End Octosnap
2021-07-23 17:32:45,338 - Send: N550 M117 Before layer 0.4 change G-code Octosnap*14
2021-07-23 17:32:45,346 - Recv: LCD status changed
2021-07-23 17:32:45,346 - Recv: ok
2021-07-23 17:32:45,349 - Send: N551 M400*38
2021-07-23 17:32:46,845 - Recv: ok
2021-07-23 17:32:46,864 - Send: N552 G1 E-0.40000 F3060.000*53
2021-07-23 17:32:46,882 - Recv: ok
2021-07-23 17:32:46,883 - Send: N553 G91*18
2021-07-23 17:32:46,886 - Recv: ok
2021-07-23 17:32:46,887 - Send: N554 G1 Z0.200 F12000.000*49
2021-07-23 17:32:46,898 - Recv: ok
2021-07-23 17:32:46,900 - Send: N555 G90*21
2021-07-23 17:32:46,902 - Recv: ok
2021-07-23 17:32:46,903 - Send: N556 G0 X247.500 Y207.870*32
2021-07-23 17:32:46,935 - Recv: ok
2021-07-23 17:32:46,936 - Send: N557 M400*32
2021-07-23 17:32:47,414 - Recv: T:225.1 /225.0 B:65.5 /65.0 T0:225.1 /225.0 @:41 B@:0 P:49.3 A:37.9
2021-07-23 17:32:47,943 - Recv: ok
2021-07-23 17:32:47,946 - Send: N558 M114*47
2021-07-23 17:32:47,964 - Recv: X:247.50 Y:207.87 Z:0.40 E:-0.40 Count X: 245.32 Y:208.34 Z:0.51 E:-0.40
2021-07-23 17:32:47,966 - Recv: ok
2021-07-23 17:32:48,363 - Send: N559 G0 X114.164 Y116.600*38
2021-07-23 17:32:48,407 - Recv: ok
2021-07-23 17:32:48,409 - Send: N560 G91*18
2021-07-23 17:32:48,427 - Recv: ok
2021-07-23 17:32:48,428 - Send: N561 G1 Z-0.200*81
2021-07-23 17:32:48,450 - Recv: ok
2021-07-23 17:32:48,452 - Send: N562 G1 E0.40000 F1440.000*31
2021-07-23 17:32:48,471 - Recv: ok
2021-07-23 17:32:48,475 - Send: N563 G90*16
2021-07-23 17:32:48,495 - Recv: ok
2021-07-23 17:32:48,496 - Send: N564 G1 F1200.000*84
2021-07-23 17:32:48,548 - Recv: ok
2021-07-23 17:32:48,552 - Send: N565 M117 End Octosnap*86
M117 After layer 0.4 change G-code Octosnap
M117 End Octosnap
2021-07-23 17:32:48,659 - Send: N569 M117 After layer 0.4 change G-code Octosnap*121
2021-07-23 17:32:48,668 - Recv: LCD status changed
2021-07-23 17:32:48,669 - Recv: ok
2021-07-23 17:32:48,671 - Send: N570 M400*37
2021-07-23 17:32:49,565 - Recv: T:224.9 /225.0 B:65.6 /65.0 T0:224.9 /225.0 @:46 B@:0 P:49.5 A:37.9
2021-07-23 17:32:49,676 - Recv: ok
2021-07-23 17:32:49,689 - Send: N571 G0 X247.500 Y207.870*37
2021-07-23 17:32:49,721 - Recv: ok
2021-07-23 17:32:49,722 - Send: N572 M400*39
2021-07-23 17:32:50,855 - Recv: ok
2021-07-23 17:32:50,857 - Send: N573 M114*38
2021-07-23 17:32:50,876 - Recv: X:247.50 Y:207.87 Z:0.40 E:-0.40 Count X: 245.32 Y:208.34 Z:0.51 E:-0.40
2021-07-23 17:32:50,877 - Recv: ok
2021-07-23 17:32:51,242 - Send: N574 G0 X114.164 Y116.600*41
2021-07-23 17:32:51,273 - Recv: ok
2021-07-23 17:32:51,275 - Send: N575 M117 End Octosnap*87
M117 Before layer 0.6 change G-code Octosnap
M117 End Octosnap
2021-07-23 17:33:21,816 - Send: N878 M117 Before layer 0.6 change G-code Octosnap*11
2021-07-23 17:33:21,826 - Recv: LCD status changed
2021-07-23 17:33:21,828 - Recv: ok
2021-07-23 17:33:21,832 - Send: N879 M400*33
2021-07-23 17:33:22,723 - Recv: ok
2021-07-23 17:33:22,740 - Send: N880 G1 E-0.40000 F3060.000*55
2021-07-23 17:33:22,757 - Recv: ok
2021-07-23 17:33:22,759 - Send: N881 G91*16
2021-07-23 17:33:22,767 - Recv: ok
2021-07-23 17:33:22,768 - Send: N882 G1 Z0.200 F12000.000*55
2021-07-23 17:33:22,777 - Recv: ok
2021-07-23 17:33:22,778 - Send: N883 G90*19
2021-07-23 17:33:22,787 - Recv: ok
2021-07-23 17:33:22,790 - Send: N884 G0 X247.500 Y207.870*34
2021-07-23 17:33:22,834 - Recv: ok
2021-07-23 17:33:22,835 - Send: N885 M400*34
2021-07-23 17:33:23,409 - Recv: T:214.5 /215.0 B:64.7 /65.0 T0:214.5 /215.0 @:62 B@:29 P:49.1 A:38.3
2021-07-23 17:33:23,887 - Recv: ok
2021-07-23 17:33:23,889 - Send: N886 M114*33
2021-07-23 17:33:23,899 - Recv: X:247.50 Y:207.87 Z:0.60 E:-0.40 Count X: 245.32 Y:208.34 Z:0.71 E:-0.40
2021-07-23 17:33:23,909 - Recv: ok
2021-07-23 17:33:24,235 - Send: N887 G0 X113.254 Y94.085*31
2021-07-23 17:33:24,280 - Recv: ok
2021-07-23 17:33:24,287 - Send: N888 G91*25
2021-07-23 17:33:24,311 - Recv: ok
2021-07-23 17:33:24,316 - Send: N889 G1 Z-0.200*90
2021-07-23 17:33:24,329 - Recv: ok
2021-07-23 17:33:24,331 - Send: N890 G1 E0.40000 F1440.000*31
2021-07-23 17:33:24,345 - Recv: ok
2021-07-23 17:33:24,347 - Send: N891 G90*16
2021-07-23 17:33:24,354 - Recv: ok
2021-07-23 17:33:24,355 - Send: N892 G1 F10952.635*108
2021-07-23 17:33:24,366 - Recv: ok
2021-07-23 17:33:24,369 - Send: N893 M117 End Octosnap*82
M117 After layer 0.6 change G-code Octosnap
M117 End Octosnap
2021-07-23 17:33:24,457 - Send: N896 M117 After layer 0.6 change G-code Octosnap*118
2021-07-23 17:33:24,472 - Recv: LCD status changed
2021-07-23 17:33:24,474 - Recv: ok
2021-07-23 17:33:24,477 - Send: N897 M400*33
2021-07-23 17:33:25,513 - Recv: T:214.4 /215.0 B:64.8 /65.0 T0:214.4 /215.0 @:65 B@:24 P:48.9 A:38.5
2021-07-23 17:33:25,616 - Recv: ok
2021-07-23 17:33:25,638 - Send: N898 G0 X247.500 Y207.870*47
2021-07-23 17:33:25,681 - Recv: ok
2021-07-23 17:33:25,682 - Send: N899 M400*47
2021-07-23 17:33:26,869 - Recv: ok
2021-07-23 17:33:26,871 - Send: N900 M114*46
2021-07-23 17:33:26,889 - Recv: X:247.50 Y:207.87 Z:0.60 E:-0.40 Count X: 245.32 Y:208.34 Z:0.71 E:-0.40
2021-07-23 17:33:26,891 - Recv: ok
2021-07-23 17:33:27,234 - Send: N901 G0 X113.254 Y94.085*16
2021-07-23 17:33:27,278 - Recv: ok
2021-07-23 17:33:27,280 - Send: N902 M117 End Octosnap*91
M117 Before layer 0.8 change G-code Octosnap
M117 End Octosnap
2021-07-23 17:34:09,177 - Send: N1217 M117 Before layer 0.8 change G-code Octosnap*55
2021-07-23 17:34:09,186 - Recv: LCD status changed
2021-07-23 17:34:09,188 - Recv: ok
2021-07-23 17:34:09,193 - Send: N1218 M400*29
2021-07-23 17:34:09,592 - Recv: T:214.7 /215.0 B:64.7 /65.0 T0:214.7 /215.0 @:82 B@:70 P:45.7 A:39.3
2021-07-23 17:34:10,098 - Recv: ok
2021-07-23 17:34:10,129 - Send: N1219 G1 E-0.40000 F3060.000*12
2021-07-23 17:34:10,154 - Recv: ok
2021-07-23 17:34:10,156 - Send: N1220 G91*32
2021-07-23 17:34:10,161 - Recv: ok
2021-07-23 17:34:10,163 - Send: N1221 G1 Z0.200 F12000.000*5
2021-07-23 17:34:10,174 - Recv: ok
2021-07-23 17:34:10,176 - Send: N1222 G90*35
2021-07-23 17:34:10,181 - Recv: ok
2021-07-23 17:34:10,183 - Send: N1223 G0 X247.500 Y207.870*20
2021-07-23 17:34:10,214 - Recv: ok
2021-07-23 17:34:10,216 - Send: N1224 M400*18
2021-07-23 17:34:11,210 - Recv: ok
2021-07-23 17:34:11,212 - Send: N1225 M114*19
2021-07-23 17:34:11,230 - Recv: X:247.50 Y:207.87 Z:0.80 E:-0.40 Count X: 245.32 Y:208.34 Z:0.91 E:-0.40
2021-07-23 17:34:11,231 - Recv: ok
2021-07-23 17:34:11,538 - Send: N1226 G0 X114.085 Y116.746*21
2021-07-23 17:34:11,575 - Recv: ok
2021-07-23 17:34:11,579 - Send: N1227 G91*39
2021-07-23 17:34:11,602 - Recv: ok
2021-07-23 17:34:11,603 - Send: N1228 G1 Z-0.200*106
2021-07-23 17:34:11,607 - Recv: T:215.3 /215.0 B:64.7 /65.0 T0:215.3 /215.0 @:66 B@:68 P:45.6 A:39.3
2021-07-23 17:34:11,630 - Recv: ok
2021-07-23 17:34:11,633 - Send: N1229 G1 E0.40000 F1440.000*38
2021-07-23 17:34:11,648 - Recv: ok
2021-07-23 17:34:11,650 - Send: N1230 G90*32
2021-07-23 17:34:11,656 - Recv: ok
2021-07-23 17:34:11,658 - Send: N1231 G1 F10952.635*94
2021-07-23 17:34:11,664 - Recv: ok
2021-07-23 17:34:11,668 - Send: N1232 M117 End Octosnap*98
M117 After layer 0.8 change G-code Octosnap
M117 End Octosnap
2021-07-23 17:34:11,753 - Send: N1235 M117 After layer 0.8 change G-code Octosnap*74
2021-07-23 17:34:11,763 - Recv: LCD status changed
2021-07-23 17:34:11,764 - Recv: ok
2021-07-23 17:34:11,768 - Send: N1236 M400*17
2021-07-23 17:34:12,848 - Recv: ok
2021-07-23 17:34:12,860 - Send: N1237 G0 X247.500 Y207.870*17
2021-07-23 17:34:12,889 - Recv: ok
2021-07-23 17:34:12,896 - Send: N1238 M400*31
2021-07-23 17:34:13,615 - Recv: T:215.2 /215.0 B:64.7 /65.0 T0:215.2 /215.0 @:71 B@:77 P:45.5 A:39.0
2021-07-23 17:34:14,020 - Recv: ok
2021-07-23 17:34:14,022 - Send: N1239 M114*30
2021-07-23 17:34:14,037 - Recv: X:247.50 Y:207.87 Z:0.80 E:-0.40 Count X: 245.32 Y:208.34 Z:0.91 E:-0.40
2021-07-23 17:34:14,038 - Recv: ok
2021-07-23 17:34:14,335 - Send: N1240 G0 X114.085 Y116.746*21
2021-07-23 17:34:14,368 - Recv: ok
2021-07-23 17:34:14,370 - Send: N1241 M117 End Octosnap*102
M117 Before layer 1 change G-code Octosnap
M117 End Octosnap
2021-07-23 17:34:39,955 - Send: N1472 M117 Before layer 1 change G-code Octosnap*37
2021-07-23 17:34:39,965 - Recv: LCD status changed
2021-07-23 17:34:39,966 - Recv: ok
2021-07-23 17:34:39,969 - Send: N1473 M400*22
2021-07-23 17:34:40,714 - Recv: T:215.1 /215.0 B:64.8 /65.0 T0:215.1 /215.0 @:79 B@:97 P:43.8 A:40.0
2021-07-23 17:34:40,891 - Recv: ok
2021-07-23 17:34:40,916 - Send: N1474 G1 E-0.40000 F3060.000*1
2021-07-23 17:34:40,928 - Recv: ok
2021-07-23 17:34:40,932 - Send: N1475 G91*38
2021-07-23 17:34:40,939 - Recv: ok
2021-07-23 17:34:40,940 - Send: N1476 G1 Z0.200 F12000.000*1
2021-07-23 17:34:40,951 - Recv: ok
2021-07-23 17:34:40,952 - Send: N1477 G90*37
2021-07-23 17:34:40,955 - Recv: ok
2021-07-23 17:34:40,956 - Send: N1478 G0 X247.500 Y207.870*28
2021-07-23 17:34:41,001 - Recv: ok
2021-07-23 17:34:41,002 - Send: N1479 M400*28
2021-07-23 17:34:42,062 - Recv: ok
2021-07-23 17:34:42,064 - Send: N1480 M114*26
2021-07-23 17:34:42,082 - Recv: X:247.50 Y:207.87 Z:1.00 E:-0.40 Count X: 245.32 Y:208.34 Z:1.12 E:-0.40
2021-07-23 17:34:42,084 - Recv: ok
2021-07-23 17:34:42,430 - Send: N1481 G0 X113.254 Y94.085*36
2021-07-23 17:34:42,472 - Recv: ok
2021-07-23 17:34:42,478 - Send: N1482 G91*46
2021-07-23 17:34:42,484 - Recv: ok
2021-07-23 17:34:42,489 - Send: N1483 G1 Z-0.200*109
2021-07-23 17:34:42,504 - Recv: ok
2021-07-23 17:34:42,514 - Send: N1484 G1 E0.40000 F1440.000*39
2021-07-23 17:34:42,525 - Recv: ok
2021-07-23 17:34:42,526 - Send: N1485 G90*40
2021-07-23 17:34:42,537 - Recv: ok
2021-07-23 17:34:42,540 - Send: N1486 G1 F7762.000*111
2021-07-23 17:34:42,560 - Recv: ok
2021-07-23 17:34:42,564 - Send: N1487 M117 End Octosnap*106
M117 After layer 1 change G-code Octosnap
M117 End Octosnap
2021-07-23 17:34:42,783 - Send: N1494 M117 After layer 1 change G-code Octosnap*80
2021-07-23 17:34:42,795 - Recv: LCD status changed
2021-07-23 17:34:42,796 - Recv: ok
2021-07-23 17:34:42,799 - Send: N1495 M400*30
2021-07-23 17:34:43,807 - Recv: ok
2021-07-23 17:34:43,816 - Send: N1496 M117 ETA is 17:35:42*114
2021-07-23 17:34:43,831 - Recv: LCD status changed
2021-07-23 17:34:43,832 - Recv: ok
2021-07-23 17:34:43,846 - Send: N1497 G0 X247.500 Y207.870*29
2021-07-23 17:34:43,890 - Recv: ok
2021-07-23 17:34:43,896 - Send: N1498 M400*19
2021-07-23 17:34:44,990 - Recv: T:215.8 /215.0 B:64.4 /65.0 T0:215.8 /215.0 @:59 B@:127 P:43.6 A:39.7
2021-07-23 17:34:45,076 - Recv: ok
2021-07-23 17:34:45,078 - Send: N1499 M114*18
2021-07-23 17:34:45,089 - Recv: X:247.50 Y:207.87 Z:1.00 E:-0.40 Count X: 245.32 Y:208.34 Z:1.12 E:-0.40
2021-07-23 17:34:45,090 - Recv: ok
2021-07-23 17:34:45,433 - Send: N1500 G0 X113.254 Y94.085*44
2021-07-23 17:34:45,474 - Recv: ok
2021-07-23 17:34:45,476 - Send: N1501 M117 End Octosnap*101
M117 End Octosnap
2021-07-23 17:35:26,612 - Send: N1784 M117 End G-code Octosnap 1 of 2*7
2021-07-23 17:35:26,623 - Recv: LCD status changed
2021-07-23 17:35:26,625 - Recv: ok
2021-07-23 17:35:26,644 - Send: N1785 M400*28
2021-07-23 17:35:26,992 - Recv: T:214.9 /215.0 B:64.8 /65.0 T0:214.9 /215.0 @:81 B@:45 P:41.4 A:40.5
2021-07-23 17:35:27,399 - Recv: ok
2021-07-23 17:35:27,418 - Send: N1786 G0 X247.500 Y207.870*30
2021-07-23 17:35:27,447 - Recv: ok
2021-07-23 17:35:27,449 - Send: N1787 M400*30
2021-07-23 17:35:28,583 - Recv: ok
2021-07-23 17:35:28,590 - Send: N1788 M114*17
2021-07-23 17:35:28,602 - Recv: X:247.50 Y:207.87 Z:1.20 E:49.14 Count X: 245.32 Y:208.34 Z:1.32 E:49.14
2021-07-23 17:35:28,603 - Recv: ok
2021-07-23 17:35:28,924 - Send: N1789 G0 X113.975 Y116.748*26
2021-07-23 17:35:28,954 - Recv: ok
2021-07-23 17:35:28,955 - Send: N1790 M117 End Octosnap*111
M117 End G-code Octosnap 2 of 2
M117 End Octosnap
2021-07-23 17:35:30,243 - Send: N1803 M117 End G-code Octosnap 2 of 2*4
2021-07-23 17:35:30,253 - Recv: LCD status changed
2021-07-23 17:35:30,253 - Recv: ok
2021-07-23 17:35:30,255 - Send: N1804 M400*26
2021-07-23 17:35:31,199 - Recv: T:216.1 /215.0 B:65.1 /65.0 T0:216.1 /215.0 @:48 B@:25 P:41.3 A:40.6
2021-07-23 17:35:32,506 - Recv: echo:busy: processing
2021-07-23 17:35:33,297 - Recv: T:216.3 /215.0 B:65.2 /65.0 T0:216.3 /215.0 @:42 B@:19 P:41.2 A:40.8
2021-07-23 17:35:34,603 - Recv: echo:busy: processing
2021-07-23 17:35:35,394 - Recv: T:216.3 /215.0 B:65.3 /65.0 T0:216.3 /215.0 @:42 B@:12 P:41.2 A:40.7
2021-07-23 17:35:36,700 - Recv: echo:busy: processing
2021-07-23 17:35:37,491 - Recv: T:216.1 /215.0 B:65.3 /65.0 T0:216.1 /215.0 @:43 B@:23 P:41.1 A:40.5
2021-07-23 17:35:38,797 - Recv: echo:busy: processing
2021-07-23 17:35:39,314 - Recv: ok
2021-07-23 17:35:39,317 - Send: N1805 M117 ETA is 17:35:26*118
2021-07-23 17:35:39,334 - Recv: LCD status changed
2021-07-23 17:35:39,335 - Recv: ok
2021-07-23 17:35:39,353 - Send: N1806 G0 X247.500 Y207.870 F12000.000*82
2021-07-23 17:35:39,382 - Recv: ok
2021-07-23 17:35:39,386 - Send: N1807 M400*25
2021-07-23 17:35:39,592 - Recv: T:216.0 /215.0 B:65.2 /65.0 T0:216.0 /215.0 @:45 B@:37 P:41.0 A:40.6
2021-07-23 17:35:40,330 - Recv: ok
2021-07-23 17:35:40,332 - Send: N1808 M114*22
2021-07-23 17:35:40,345 - Recv: X:247.50 Y:207.87 Z:100.63 E:-0.80 Count X: 245.32 Y:208.34 Z:100.75 E:-0.80
2021-07-23 17:35:40,347 - Recv: ok
2021-07-23 17:35:40,729 - Send: N1809 G0 X125.000 Y210.000*29
2021-07-23 17:35:40,755 - Recv: ok
2021-07-23 17:35:40,760 - Send: N1810 G1 F10200.000*91
2021-07-23 17:35:40,768 - Recv: ok
2021-07-23 17:35:40,775 - Send: N1811 M117 End Octosnap*105
Side note. My preference for where to put the snapshot is in the after layer change because the slicer generated retract happens between the before layer change and after layer change custom gcodes. And, because the after layer change custom gcode is inserted by PrusaSlicer before the first layer I'm not sure if it is necessary to have any octolapse triggers in the start gcode. But, I want to have my first snapshot be of the empty bed, taken before the nozzle is at full temperature (and thus not oozing). I want to be able do this by putting the trigger where I want in my start gcode and use a conditional to put the trigger in the after layer change for every layer number except zero.
Hopefully I can summon the spirit of @FormerLurker to help with this or get advice if this should be escalated to github as an actual bug report.
My environment:
OctoPi: 0.17.0 (Yeah, I haven't upgraded to 0.18.0 yet)
OctoPrint: 1.6.1
Python: 3.7.3
Raspberry Pi 4
Prusa Original MK3S fw: 3.10.0
PrusaSlicer 2.3.2 (Yeah, I haven't upgraded to 2.3.3 yet)
Here is my Systeminfo bundle:
octoprint-systeminfo-20210723173732.zip (677.7 KB)
Here is the 3mf of my test print. (Change the .zip extension to .3mf):
OctoSnap_Test.zip (22.0 KB)
Here is the resulting gcode as downloaded from Octoprint:
OctoSnap_Test_0.4n_0.2mm_PLA_MK3S_4m.gcode (91.3 KB)
