XYZ new Jan2020 firmware allowed Cura to slice and print to the Da Vinci Junior 1.0 (basic no wifi). The original proprietary xyzware software used a 3w format of encrypted gcode. XYZ printers were cheap but they previously locked in expensive filament. The restrictions are now gone and so I'd like to use the printer again as its good enough for my purposes. Octopi sounds brilliant if /i can get it to work.
I read another post on the Da Vinci Junior 1.0 wifi version which said that as the printer doesnt have "marlin", Octoprint wouldnt work as it needs gcode. I think the new firmware may fix this and allow gcode. Yet another post said it does have marlin.
https://community.octoprint.org/search?q=da%20vinci
I tried Octopi on a pi 3B but the printer connection shows as offline although the pi seems to know something is connected to the usb as i show ttyACM0 in log but fails as it is "busy" - even though the printer is just switched on but doing nothing.
I'd very much like to get this to work but please tell me if it is not doable so I stop going in circles.
I searched for Error 16 and tried various solutions mainly for Arduinos. /nothing worked and so this seems like a monty python dead parrot sketch ...
I have also tried connecting the different baud rates one by one and also tried another usb cable.
If it is possible, please help. /i think this is a popular printer and so its likely others would be interested too.
As my printer is the basic Da Vinci Junior version without wifi, this would mean I can stop directly connecting my laptop to the printer which at present is inconvenient.
Log from terminal:
Serial port list: [u'/dev/ttyACM0']
Connecting to: /dev/ttyACM0
Connected to: Serial<id=0x731bfdb0, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Starting baud rate detection...
Trying baudrate: 115200
Send: N0 M110 N0*125
Baudrate test retry #1
Baudrate test retry #2
Baudrate test retry #3
Baudrate test retry #4
Trying baudrate: 250000
Trying baudrate: 230400
Trying baudrate: 57600
Trying baudrate: 38400
Trying baudrate: 19200
Trying baudrate: 9600
Changing monitoring state from "Detecting baudrate" to "Error: No more baudrates to test, and no suitable baudrate found."
Changing monitoring state from "Error: No more baudrates to test, and no suitable baudrate found." to "Offline (Error: No more baudrates to test, and no suitable baudrate found.)"
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial<id=0x6ac8f110, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
No answer from the printer within the connection timeout, trying another hello
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
Da Vinci Junior 1.0 (note not wifi version)
Octopi version: octopi-buster-lite-0.17.0.zip
pi 3B
Windows 10 using Chrome browser
