Not really a problem, just a question. Can octopi/raspberry pi be configured to take a dynamic hostname from the DCHP server when it the ip is assigned?
Seaching lead me to the instructions on manually updating the hostname using raspi-config and that is easy enough to change the hostnames. This lead me to more of a networking question as it relates to octopi and I figure it would not hurt to ask folks who are much smarter than I am in this area. I also acknowledge it is easy enough to just edit the hostname manually, and I have done this.
run sudo raspi-config select "2. Hostname" and follow the instructions
deferred
I have a fairly basic /24 lan in my home over cat 6 with ubiquiti switches and each pi is hardwired using ethernet/cat6.
