I cannot connect to octopi.local via the web interface. The background is I just unpacked my printer after a year of being in the box, when I did so, octopi worked fine, but warned me to upgrade from python2. After imaging the latest version using the raspberry pi imager, the problem occured (before I got a chance to restore backup)
Made sure the wifi locale was correct. Set the IP address to 192.168.68.250. Can ssh to octopi.local and ping octopi.local without issue.
Can't access logs, but here's the ping
ping octopi.local
PING octopi.local (192.168.68.250): 56 data bytes
64 bytes from 192.168.68.250: icmp_seq=0 ttl=64 time=8.612 ms
I'm using the TP-link mesh network system. As stated above, this worked fine prior to upgrading.
