VIP TZC3MV167W00251 for example (ONVIF RTSP security camera type - fairly generic, various others may be utilised, all of which were intended to be accessed by rtsp until discovered a lack of support)
Lack of support
Investigate RTSP support, been astonished at the archaic mjpeg foundation for webcams, explored plugins for options, researched rtsp solutions, all of which refer to mjpeg transcoding (astonished again) discover there is a different cam stack, (woohoo), I'll probably be able to leverage that with an update, discovered just updating is apparently not an option.
Not Applicable
Not Applicable
You
octoprint-systeminfo-20240818125152.zip (1.3 MB)
can download this in OctoPrint's System Information dialog ... no bundle, no support!)
x86-64 deployment of octoprint on ubuntu 24.04 in proxmox virtual machine HA environment leveraging usbipd (USB over TCP/IP) connectivity to printer with pi4B exporting printer USB over ethernet/wlan failover bond, with the same pi also handling a touch screen running octodash, and the intention of exporting cams (USB or Pi cams) over network via h264/h265 RTSP * this last aspect just hit a brick wall.
It's basically an ethernet connected printer with a thin client touchscreen and rtsp cams managed by octoprint running in a private proxmox cloud.
Super happy with the deployment (used octodeploy) and solution development right up until I looked into enabling web cams and was astonished by apparent mjpeg dependency.
Intending to write up a high-availability octoprint howto when solution is complete. Version 1.10.2, don't recall any dialogue re: new camera stack from deployment tool; if I was presented with one and it's labelled as experimental I probably declined.
Not keen on reinstalling, have a philosophical objection to the popularity of rebuilding as an easy (lazy) solution (often just hides a problem and destroys evidence of it instead of understanding it), particularly so as I'm making good progress on a bespoke installation type and would prefer not to go backwards by actioning some kind of uninstall and re-deploy (I have more to configure here than just octoprint)
Any suggestions? Wait until modern camera support is available? Should I just do without camera integration for the time being if I don't want to redeploy, or is there another option I'm missing?
Yes I'm a noob octoprint user. Yes I'm aware the config I've just described will trigger some people to berate me for doing something they consider wrong. Hoping we can focus on the solution and present an option that isn't some kind of redeployment. I'm not here to justify deployment decisions to naysayers, I'm looking into more advanced cam support. Sorry, please don't take offence I'm just keenly aware that if I'd asked in forums how to do this deployment I'd have received a torrent of "don't do it that way!" by people with little imagination and often less experience. That would be true of the vast majority of support forums in my experience.
If we can't do something other than redeploy I might handle cameras independently of octoprint until camera support is modernised in stable.
I do understand that for the vast majority of octopi users a redeployment makes sense. I do understand what I'm asking is probably outside the support norms.
I am surprised at the camera stack support state, mostly I'm just looking for options that don't involve one step forward two steps back.
