Cannot change wifi credentials for different router
I cannot change the wifi info on the pi. This worked on my wifi, but I'm giving my printer to my son and I cannot get it to connect to his wifi.
I went to edit the octopi-wpa-supplicant.txt, but it doesn't exist. I found octopi-network.txt. But that file says Using this file to configure your network connection is no longer supported. Please use wifi.nmconnection instead.
So I opened that file using Notepad++ and followed the instructions there. The only thing I did was to uncomment all the lines except the first one and fill in his SSID and Password. This is my new wifi.nmconnection file:
# Uncomment everything below this line and set your ssid and password
[connection]
id=wifi
uuid=593819b8-135a-4a3e-9611-c36cdeadbeef
type=wifi
interface-name=wlan0
[wifi]
mode=infrastructure
ssid=<his SSID>
[wifi-security]
auth-alg=open
key-mgmt=wpa-psk
psk=<his password>
[ipv4]
method=auto
[ipv6]
addr-gen-mode=default
method=auto
[proxy]
I cannot connect to the pi and it's not connecting to the router.
I cannot communicate with it.
I'm not sure, but it was the latest versions that I downloaded and installed in November 2025. I had updated it at that time to get the latest Python version. It connected to my network, and I had no issues with it. But it won't connect to my son's wifi even after editing the wifi.nmconnection file. I've double- and triple-checked the SSID and Password. I can connect my laptop and phone to his network, but I cannot get the pi to connect. I've logged into the router, and there is no connection to the pi.
I've searched the forum, but I cannot find anyone having issues with setting the new wifi with wifi.nmconnection. There are some older posts when it was octopi-wpa-supplicant.txt or octopi-network.txt. Sorry if I missed it somewhere.
So I used an Ethernet cable to connect to the pi. That works. I used
sudo iwlist wlan0 scan
to view the wifi networks. There are four entries for my son's SSID listed. Quality varies from 50/70 to 58/70. So, clearly, the pi can see the network but refuses to connect to it.
Now that I can connect with wired connection here's the other info you were asking for:
OctoPrint 1.11.5
OctoPi Version 1.1.0, running on Raspberry Pi 3 Model B Plus Rev 1.3
octoprint-systeminfo-20260207155359.zip (11.6 KB)
And here's my Systeminfo Bundle.
If you can connect over ethernet, that's a better option anyway. If that's inconvenient use the ethernet connection and SSH to the pi and run sudo raspi-config and try to set-up the wifi connection from within there.
Thanks! That worked. I was able to set up the new wifi credentials. Reboot and it connected.
Any idea why changing wifi.nmconnection doesn't work like it's supposed to?
If you were editing the file over SSH, then you probably were editing the wrong one maybe. The file is originally stored in the root of the SD card's boot partition. That ends up being a different path once booted and you should edit the file /boot/firmware/wifi.nmconnection not /boot/wifi.nmconnection. The former is where the custom service grabs the file and moves into the proper place on the system for network-manager to pick it up.
I was editing it on the SD card. I plugged the SD card into my laptop and used Notepad++ to open and edit it. I found the file in the root folder on the SD card. Anyway, I got it to work with sudo raspi-config over the Ethernet connection. This may be helpful for anyone else who can't get it to work by editing wifi.nmconnection.
