Octoprint was asking to update something earlier. I didn't pay a whole lot of attention to what, I just let it do it.
After that, I cannot connect to it at all.
Not through the Web Interface, nor through ssh.
I do get a reply to a ping, so it is alive...
No connection to Rpi.
Switch it off and on again...
$ ping 192.168.1.15
Pinging 192.168.1.15 with 32 bytes of data:
Reply from 192.168.1.15: bytes=32 time=117ms TTL=64
Reply from 192.168.1.15: bytes=32 time=15ms TTL=64
Reply from 192.168.1.15: bytes=32 time=26ms TTL=64
$ ssh -Y pi@192.168.1.15
ssh: connect to host 192.168.1.15 port 22: Connection refused
My router is habitually unhelpful: I am yet to find any sensible way of getting it to communicate.
There is a web interface of sorts on its IP address, but it's a bit poor.
follow the troubleshooting ssh to the .16 address and see if the octoprint processes are running... and DO NOT just switch off/on power to reboot the pi. you will corrupt your sd card and have to reload all from scratch if the sd card itself isnt damaged
Sorry, I wasn't clear: I'm sorted now. I thought I'd leave the post up for the next fool who missed the bleedin' obvious.
What else are you supposed to do?
Drag over a keyboard and monitor, plug in, log on and shut down?
Power down is not ideal, but what choice is there, unless you've fitted a reset button?
