Was all working fine, I updated to latest version in the browser (sorry didn't note details) and now unable to connect over wifi:
Browser fails to load octopi.local
I cannot SSH to pi@octopi.local
Cannot export g-code to Octoprint from Prusa Slicer, it times out
I have a Pi screen and octodash loads and is communicating with my Prusa I3 MK3S.
Nothing has changed on my Mac or the network/router, Mac has internet connection.
I have no clue what to do since I can't ssh to check anything, I was hoping to avoid a complete re-install so any pointers in the right direction would be much appreciated.
I would need to move my Mac to try a wired connection so that is not easy.
Shutdown Pi and printer several times
Ping octopi - finds correct IP address but requests timeout (expected?)
Tried traceroute and ping to IP address and octopi.local - no luck
Looked through a few threads on here for clues but didn't see anything helpful.
On Mac running Big Sur 11.0.1 I can't find any log files.
Folder ~/Library/Application Support/... does not contain an Octopi/Print folder.
Searched the HHD and couldn't find anything with hidden files enabled.
The only thing I can find on my Mac is a folder: USER\Applications\OctoPrint but it appears to be empty.
IP address is fixed on router.
