Hey Guys, new to 3d printing world, first time trying to setup octoprint. Please help, its been a rocky ride the whole way from adding bootloader to now octopi install.
What is the problem? Cannot connect Octopi to WIFI or Ethernet
- Looked up Multiple guides on youtube and octoprint forum regarding setup
WiFi setup and troubleshooting - Confirmed my password is correct multiple times
- Burned images using multple software (Rufus, Etcher (Failed), Win32 disk imager)
- Carefully disconnect MicroSD everytime
- Tested with multiple power source (Laptop C Charger, 1amp brick, 2.4amp power bar usb)
- attempt to connect to different SSID (2.4ghz network, never attempted 5ghz)
- powered on octopi right beside my router (no DHCP)
- powered on octopi with ethernet (no DHCP)
- Used advanced IP scanner, checked my router for local lease devices never seen octopi
- Attempted to SSH by sharing my wifi connection from laptop and ethernet to octopi(Connection refused with putty port 22)
- I do not have mini hdmi cable nor a monitor with mini hdmi so I cant see the raspi interface, I have no way of manually configuring or grabbing any logs.
- This person mentioned something about how octopi sees space in SSID when running wifi scan
WiFi Connectivity Issues
I don't quite understand this space they're talking about.
Hardwares: raspberry pi 4b, Asus RT-86u 2.4Ghz SSID, Windows 10 64bit, Octoprint 0.17.0
