unable to connect to printer What did you already try to solve it?
I have tried opening in safe mode as well as 5 different usb cables Logs (syslog, dmesg, ... no logs, no support)
If you connect the printer t the PC with the USB cables you tested, does one make the usual USB connection sound?
If not, these cables are not suitable for data connection ore there is an issue with the USB port of the printer.
