What is the problem? Have connected Raspberry Pi to Einsy Rambo via port J19 and GPIO pins, and Octopi does not autodetect printer. Pi is seeing my network (wireless).
What did you already try to solve it? Have confirmed pinout and cable integrity (checked continuity of each lead, and checked connection to sockets). With several (many) attempts to add serial ports, I was finally able to get it to 'see' /dev/ttyAMA0, but it failed to connect to that. Further attempts to add serial ports (/dev/ttyS0) have gone unnoticed by system, despite saving and rebooting both Octopi and system.
Additional information about your setup OctoPrint v1.3.8, OctoPi v0.15.1, Custom-Built printer with Einsy Rambo board, RepRap Discount Smart Controller, Pi 3B, Marlin firmware, output on terminal tab (see below);
Connecting to: /dev/ttyAMA0
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial<id=0x744a6950, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Starting baud rate detection
Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2417
Changing monitoring state from "Detecting baudrate" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2417)"
Serial port list: ['/dev/ttyAMA0']
Connected to: Serial<id=0x6eeec250, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
