I recently moved into an apartment that requires a two step wifi login process like you would find in a cafe/hotel. This means basic SSID/password followed by a browser username/password. I do not know the correct formatting in the octopi -wpa- supplicant .txt file to get around this level of wifi security or if there are other ways to get around this.
I have searched the internet far and wide to find an easy solution. While I have found some posts that refer to this issue, they seem overwhelming (I have no background in coding) or out of date.
Raspberry Pi 3b
Security type: WPA2-Personal
Thanks for any help.
