I updated my pi to the latest version today after not using it for a while, during the update it lost connection and now im receving an error saying the server is not running and a tmc connection error on my printer. Im not able to access the UI
I am not too familiar with the software and terms people are using on here, for instance how to access safe mode ect.
no
no
The OctoPrint server is currently not running
If you just started up your Raspberry Pi, please wait a couple of seconds, then try to refresh this page.
If the issue persists, please log into your Raspberry Pi via SSH and check the following:
- Verify that the process is running:
ps -ef | grep -i octoprint | grep -i pythonshould show a python process:
pi@octopi:~ $ ps -ef | grep -i octoprint | grep -i python
pi 1441 1 6 11:12 ? 00:00:15 /home/pi/oprint/bin/python
/home/pi/oprint/bin/octoprint --host=127.0.0.1 --port=5000
- If it isn't, the question is why. Take a look into
~/.octoprint/logs/octoprint.log, there might be an error logged in there that helps to determine what's wrong. - You might also want to try if you can restart the server (if no obvious error is visible):
sudo service octoprint restart.
If all that doesn't help to trouble shoot the issue, you can seek support on the OctoPrint Community Forum. Please provide your OctoPi and OctoPrint versions as well as your octoprint.log and explain what you already tried and observed as detailed as possible.
