Cannot get Octoprint to connect to wifi on startup
I can't seem to connect to the wifi automatically with my RaspberryPi at startup.
Nope, there is no critical error, simply
Nope not tried
octoprint-systeminfo-20240622213649.zip (41.7 KB)
octoprint-logs.zip (69.1 KB)
Hardware
RaspberryPi B+
Fresh install with Raspberry Pi Imager and wifi information
On startup : Only wifi with a good wpa_supplicant.txt
The wifi dongle is TP-Link WN725N
On debug after failed startup : Ethernet connection
result of cat /etc/wpa_supplicant/wpa_supplicant.conf
network={
  ssid="Al&Al4Ever"
  psk="doubletriplecheckedverysimplepassword"
country=FR # France
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
result of lsusb
Bus 001 Device 005: ID 0483:5740 STMicroelectronics Virtual COM Port
Bus 001 Device 004: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
Bus 001 Device 003: ID 0424:ec00 Microchip Technology, Inc. (formerly SMSC) SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Microchip Technology, Inc. (formerly SMSC) SMC9514 Hub
result of wpa_supplicant -h
drivers:
  nl80211 = Linux nl80211/cfg80211
  wext = Linux wireless extensions (generic)
  wired = Wired Ethernet driver
  macsec_linux = MACsec Ethernet driver for Linux
  none = no driver (RADIUS server/WPS ER)
result of sudo wpa_supplicant -Dwext -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0
rfkill: Cannot get wiphy information
ioctl[SIOCSIWAP]: Operation not permitted
ioctl[SIOCSIWENCODEEXT]: Invalid argument
wlan0: Trying to associate with 36:94:54:98:7f:48 (SSID='Al&Al4Ever' freq=2412 MHz)
Failed to add supported operating classes IE
ioctl[SIOCSIWFREQ]: Operation not supported
wlan0: Association request to the driver failed
wlan0: Associated with 36:94:54:98:7f:48
wlan0: WPA: Key negotiation completed with 36:94:54:98:7f:48 [PTK=CCMP GTK=TKIP]
wlan0: CTRL-EVENT-CONNECTED - Connection to 36:94:54:98:7f:48 completed [id=0 id_str=]
result of sudo wpa_supplicant -Dnl80211 -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0
Successfully initialized wpa_supplicant
nl80211: Driver does not support authentication/association or connect commands
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
wlan0: Failed to initialize driver interface
result of sudo iwlist wlan0 scan
Cell 01 - Address: 36:94:54:98:7F:48
                    ESSID:"Al&Al4Ever"
                    Protocol:IEEE 802.11bg
                    Mode:Master
                    Frequency:2.412 GHz (Channel 1)
                    Encryption key:on
                    Bit Rates:54 Mb/s
                    Extra:rsn_ie =30180100000fac020200000fac04000fac020100000fac020000
                    IE: IEEE 802.11i/WPA2 Version 1
                        Group Cipher : TKIP
                        Pairwise Ciphers (2) : CCMP TKIP
                        Authentication Suites (1) : PSK
                    Quality:0  Signal level:0  Noise level:0
How far are.you from the WiFi router? According to iwlist wlan0, there is zero signal
I'm at 6.6 meters from the router, the only obstacle is a wooden panel, otherwise it's a straight line.
Also all the other wifi detected have those informations :
                    ESSID:"Al&Al4Ever"
          Cell 02 - Address: A8:6A:BB:F4:3D:00
                    ESSID:"Bbox-B13A0733"
          Cell 03 - Address: 50:39:2F:3A:5E:40
                    ESSID:"Livebox-5E40"
          Cell 04 - Address: CC:2D:1B:62:A1:6E
                    ESSID:"SFR_A168"
But as you saw in the other commands, it still detected it, and with a command line I could connect to it.
That dongle only supports 2.4 GHz. Have you checked the Wifi hotspot is set to 2.4 GHz?
It is as the scan shows :
