I set up Octopi (see Screenshot, sorry it's in German), setting a User Name (Benutzername) and Password (Passwort) and so on. This user name seems to be the SSH PW and User, but not the login data for Octoprint. But I do not see anywere during the setup where I could actually chose the user and pw for the Octoprint login, and so, when I connet to the prusasfl.local host via my browser, I can't login, no matter which user or pw I try (obviously, since I did not not set any). So where and how can I actually set a user and PW for Octoprint?
edit: So after some more looking around I found out that there should be a setup wizard when starting octoprint for the first time, which did not happen. I found 2 solutions, number 1 being:
rm ~/.octoprint/users.yaml
sed -i -e 's/firstRun: false/firstRun: true/g' ~/.octoprint/config.yaml
which does not work since there is no users.yaml, number 2 deleting the whole /home/prusasfl/.octoprint which it won't let me do. I am stumped and have no idea how I can get the wizard to run.
edit2: SOLVED! Sometimes it's so simple: Tried using another browser - didn't work. Tried using a third browser, and suddenly, the wizard started!
Tried to find people with a similar problem online, but found nothing.
No, and I don't see how that would help
Can't access the logs
OctoPi 1.0.0 with Octoprint 1.10.2
