I've been trying, and failing, to use Putty to SSH into Octopi. Putty will connect to the Pi, but will not accept any username/password. I cannot login at all.
I have tried the default pi/raspberry login combination as well as the ones I assigned with Raspberry Pi Imager and every combination thereof. I also tried the built-in Windows SSH with the same results.
Additional information about your network
The boot disk was created using Raspberry Pi Imager as per Prusa's instructions. My OS is Windows 10. Everything is US standard configuration.
Created octoprint-password.txt in the main directory using Notepad++ just to be sure. Reinserted the card into the Pi and booted. Still won't accept the password. Just to be clear, I'm a bit of a noob at this.
Raspberry Pi Imager should be the most reliable flashing tool, there are others (Etcher, Win32DiskImager) but none offer a way to configure the WiFi, username and password etc. before flashing.
I assume when you say it doesn't accept your password that you type it and you get 'incorrect password' back? Have to ask because sometimes people are confused by nothing showing up when typing the password.
