Just installed Octopi 0.16.0 on a RPI3 B+ running Octoprint 1.3.10. I am following the instructions found here: https://www.youtube.com/watch?v=7Saa1HpLRoM&list=PLkwzDQxW75SSdhQ_Gt_3qu_vwQMKYIJop&index=13&t=0s
I have been able to duplicate 2 instances of OctoPrint in the /etc/init file successfully and rename printers in the GUI. All three of my printers are TAZ 5s so I have found some differences in the attributes using the diff command in the terminal.
I used the diffcommand to determine the differences in the attributes on the two printers since the vendor id and model are identical. Here is the output:
--- devInfoACM0 2019-08-12 18:53:10.538252534 +0100
+++ devInfoACM1 2019-08-12 18:53:19.878219174 +0100
@@ -5,13 +5,13 @@
A rule to match, can be composed by the attributes of the device
and the attributes from one single parent device.
- looking at device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.0/tty/ttyACM0':
- KERNEL=="ttyACM0"
+ looking at device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.0/tty/ttyACM1':
+ KERNEL=="ttyACM1"
SUBSYSTEM=="tty"
DRIVER==""
- looking at parent device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.0':
- KERNELS=="1-1.1.2:1.0"
+ looking at parent device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.0':
+ KERNELS=="1-1.1.3:1.0"
SUBSYSTEMS=="usb"
DRIVERS=="cdc_acm"
ATTRS{authorized}=="1"
@@ -24,8 +24,8 @@
ATTRS{bmCapabilities}=="6"
ATTRS{supports_autosuspend}=="1"
- looking at parent device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2':
- KERNELS=="1-1.1.2"
+ looking at parent device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3':
+ KERNELS=="1-1.1.3"
SUBSYSTEMS=="usb"
DRIVERS=="usb"
@@ -42,8 +42,8 @@
ATTRS{bmAttributes}=="c0"
ATTRS{busnum}=="1"
ATTRS{configuration}==""
- ATTRS{devnum}=="4"
- ATTRS{devpath}=="1.1.2"
+ ATTRS{devnum}=="5"
+ ATTRS{devpath}=="1.1.3"
ATTRS{devspec}==" (null)"
ATTRS{idProduct}=="0001"
ATTRS{idVendor}=="27b1"
@@ -53,7 +53,7 @@
ATTRS{product}=="RAMBo"
ATTRS{quirks}=="0x0"
ATTRS{removable}=="removable"
- ATTRS{serial}=="640363532303513021E1"
+ ATTRS{serial}=="740343139383513071B0"
ATTRS{speed}=="12"
ATTRS{urbnum}=="11"
ATTRS{version}==" 1.10"
@@ -182,7 +182,7 @@
ATTRS{inv_sel_hsic}=="Invert Select HSIC = 0x0"
ATTRS{mode}=="Mode = 0x1"
ATTRS{mode_ch_tim_en}=="Mode Change Ready Timer Enable = 0x0"
- ATTRS{rd_reg_test}=="Time to read GNPTXFSIZ reg 10000000 times: 900 msecs (90 jiffies)"
+ ATTRS{rd_reg_test}=="Time to read GNPTXFSIZ reg 10000000 times: 890 msecs (89 jiffies)"
ATTRS{regdump}=="Register Dump"
ATTRS{regoffset}=="0xffffffff"
ATTRS{regvalue}=="invalid offset"
I settled on the following in the modifications to the rules file at: /etc/udev/rules.d/99-usb.rules
SUBSYSTEM=="tty", ATTRS{serial}=="640363532303513021E1", ATTRS{devpath}=="1.1.3", SYMLINK+="ttySHANNON"
SUBSYSTEM=="tty", ATTRS{serial}=="740343139383513071B0", ATTRS{devpath}=="1.1.2", SYMLINK+="ttyBOOLE"
I have rebooted and I still see ttyACM0 and ttyACM1 in the "Serial Port" section under "Connections".
Should I be using different attributes to identify the printers?
