OctoPrint, on a Pi Zero 2 W, takes hours to restore a backup from a Pi3.
Reformatted SD card to try a new image, made another backup, tried a backup from another instance of Octoprint.
N/A - it's a new install that always goes directly to the install page.
This is the bundle from the Pi3.
octoprint-systeminfo-20240228234502.zip (67.6 KB)
As best I can tell, the Pi Zero 2 W is running Version 1.9.3, but without being able to get past the config screen, I can't be sure.
I had a Pi3 with 2 instances of OctoPrint on it. I kept both up to date. One ran a Prusa printer, one ran an Ender 3 Pro. I made a backup of the Prusa instance and restored it to a Pi Zero 2 W (call it 0P, for Zero Prusa). It was no trouble at all. It did take some time to restore the backup from the Pi3, but at least the status in the window was updating, telling me what was being set up or what plugin was being installed.
After a successful transfer of all the settings from the Prusa instance on the Pi3, I got another Pi Zero 2 W, which I am now trying to use for the Ender. (Call this Pi the 0E, for Zero Ender.) It is, as best I can tell, the same OctoPrint version as the 0P system. (I used the Raspberry Pi Imager, which downloaded the OctoPrint image for 0E. I did this less than a week after doing the same for the image in the 0P system. So it's possible 0P is a version older than 0E, but I doubt it. If anything, the 0E image is newer.)
I downloaded the backup from the Pi3 Ender instance of OctoPrint, the same way I did from the Prusa instance, and then I tried to restore it on the setup screen of the 0E system. I have tried this multiple times. Both backups have excluded timelapses and uploaded files. Both backup images are between 85k -95k in size. I have tried starting restoring the image to this 0E several times. I always get the modal window with the message, "Uploading backup, this can take a while. Please wait..." but it never changes. One time I let it run for about 3 hours and it never changed.
I did a new backup from the Ender and tried restoring that. Same thing. I tried restoring the Prusa backup image to the 0E system and the same thing happened. I burned a new image of OctoPrint on my MicroSD card and started all over again. Same thing with each test restore.
I'm having a supposedly unrelated problem: Whenever I connect with ssh, the connection always drops within 10 minutes. I've never had this issue before, but I'm mentioning it since I'm wondering if this could signify a problem with the Pi Zero 2 W's wifi connection or something like that.
