When trying to set buadrate with auto, I get Offline (Error: No more baudrates to test, and no suitable baudrate found.). My print is Monoprice Select Mini v2. It works fine on my Pi with the same cable.
- Confirmed laptop ports are functional with other devices
- Confirmed correct port and permisisons
- Have Monoprice Connection Fix plugin
- Same cable as working Pi
- Terminal: https://pastebin.com/raw/eeMfM4d3
- octoprint.log: https://pastebin.com/raw/2hYz9Jwc
- OS: Arch Linux
- Using Docker with latest Octoprint
Thanks.
