Trying to update from 1.6.0 to 1.6.1. I get the message "The update did not finish successfully. Please consult octoprint.log and plugin_softwareupdate_console.log for details."
I tried looking through the logs but I really don't know what I'm looking at. Restarted the pi, restarted octoprint, tried running in safe mode, nothing works.
Yes.
No.
octoprint-systeminfo-20210619055106.zip (27.6 KB)
Octoprint 1.6.0, Ender 3 Pro, Chrome, Windows 10
Here's the only log I could find.
octoprint-logs.zip (17.1 KB)
Hmmm... Seems like you have some issues with your install generally. The update command is not producing any output, just failing, and there's a few errors that make it seem like something has gone sideways.
Try installing it using SSH, log into your Pi and execute this command:
~/oprint/bin/pip install --force-reinstall --no-cache-dir OctoPrint==1.6.1
It may take a while but that should sort some issues. If that command fails, then let us know any output you got from it.
Thank you so much for the advice. I gave that a shot, it seemed like it was going ok then I received the following:
[/quote]ERROR: Error [Errno 12] Cannot allocate memory while executing command python setup.py egg_info
ERROR: Could not install packages due to an EnvironmentError: [Errno 12] Cannot allocate memory
How much memory have you left?
You can find it at the end of the files sidebar
25.5GB left. Think thats plenty lol
That's disk.
@Adam_Zies-Way to check free mem execute free -mt via SSH. You'll need to do this when the issue arises.
pi@octopi:~ $ free -mt
total used free shared buff/cache available
Mem: 874 69 605 18 199 731
Swap: 99 37 62
Total: 974 107 667
Looks OK. Was this as the issue was occurring?
No that was with everything sitting, idling as it were. I ended up writing a new image to the SD and just redoing everything. After that the update went through without a problem. I really hate doing things that way, but it worked. Thank you for all your help.
