Cannot view Raspberry Pi stream after new router installed
-Day/Night camera: Amazon.com
Moved printer to a new network where webcam streaming was working. Before I could do a test print, the network had a modem/router change from Spectrum (listed at end). Now I'm able to connect to OctoPrint on my RaspPi comp and queue jobs. My webcam does not broadcast.
Error from http://(local ip)/webcam/?action=stream :
503 Service Unavailable
No server is available to handle this request.
Error from (local IP)/#control :
Webcam stream not loaded
It might not be configured correctly or require authentication. You can change the URL of the stream under "Settings" > "Classic Webcam" > "Stream URL". If you don't have a webcam you can also just disable webcam support there.
Currently configured stream URL: /webcam/?action=stream
  • Updated/upgraded/restarted Raspi comp
  • Ran "raspistill -o Desktop/image.jpg" which resulted in a picture from the webcam. So webcam is connected to Raspi comp
  • Confirmed Haproxy settings match the settings listed here for Raspbian 10 (Buster)
  • looked on forums for similar problem, could not find any.
Yes
No, webcam still not broadcasting
browser.user_agent: Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:109.0) Gecko/20100101 Firefox/115.0
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1400.0
env.hardware.ram: 914006016
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.throttle_state: 0x80000
env.python.pip: 22.2.1
env.python.version: 3.7.3
env.python.virtualenv: True
octoprint.last_safe_mode.date: unknown
octoprint.last_safe_mode.reason: unknown
octoprint.safe_mode: False
octoprint.version: 1.9.2
printer.firmware: Prusa-Firmware 3.11.0 based on Marlin
systeminfo.generated: 2023-08-22T06:56:53Z
systeminfo.generator: zipapi
-Raspberry Pi 3b+ rev 1.3
-Raspbian 10 (Buster)
-new Spectrum Router: SAX1V1K
