PiCam HQ
Accessing the UI on Edge works completely fine. It also works on Firefox iOS but if i log in on my windows 10 machine, it will flash 2 frames of the stream then either go black or glitch out with a bunch of artifacting bands and flash.
Snapshot loads but stream does the same thing and just blanks out after 2 frames.
I have been using edge to monitor and sometimes even Cura but i just want to be able to have a tab for my printer and not use edge
tested on all of my browsers only works on iOS and edge. even found an old topic that told me to download an extension that removes an * from the url but didnt change anything.
no logs in /var/log/webcamd.log
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.141 Safari/537.36 OPR/73.0.3856.396
connectivity.connection_check: 8.8.8.8:53
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1500
env.hardware.ram: 1903988736
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.4
env.python.pip: 21.0
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.5.3
printer.firmware: Marlin 2.0.7.2 (Feb 1 2021
