Camera model. Raspberry Pi Camera Rev 1.3
What is the problem?. The webcam stream is not loading, also performing a stream test does not show anything
I tried to upgrade, but that did not resolve the issue:
sudo apt-get update --fix-missing
sudo apt-get upgrade
I also tried to take a picture using the camera command line. I was able to capture an image using the following command, however it does not look good and looks like it is mainly noise. The image is attached:
I also verified that the camera was enabled via: raspi-config
The camera also seems to be found and supported via:
vcgencmd
raspistill -vf -hf -o cam2.jpg -v
raspistill -o image.jpg -v
/var/log/webcamd.log:
i: select() timeout
i: cleaning up resources allocated by input thread
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
raspi
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Mar 4 20:52:45 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
i: Frames Per Second.: 10
i: Format............: JPEG
o: HTTP Listen Address..: 127.0.0.1
Goodbye...
i: select() timeout
syslog:
Mar 4 20:52:45 octopi kernel: [ 7.806135] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
Mar 4 20:52:45 octopi kernel: [ 7.806192] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
Mar 4 20:52:45 octopi kernel: [ 7.822612] bcm2835-v4l2-0: scene mode selected 0, was 0
Mar 4 20:52:45 octopi kernel: [ 7.826780] bcm2835-v4l2-0: V4L2 device registered as video0 - stills mode > 1280x720
Mar 4 20:52:45 octopi kernel: [ 7.832931] bcm2835-v4l2-0: Broadcom 2835 MMAL video capture ver 0.0.2 loaded.
Mar 4 20:52:45 octopi kernel: [ 7.984530] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
Mar 4 20:52:45 octopi kernel: [ 8.032025] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
Mar 4 20:52:45 octopi kernel: [ 9.374672] random: crng init done
Mar 4 20:52:45 octopi kernel: [ 9.374689] random: 7 urandom warning(s) missed due to ratelimiting
Mar 4 20:52:45 octopi kernel: [ 9.739681] uart-pl011 3f201000.serial: no DMA platform data
Mar 4 20:52:45 octopi streamer_select[411]: Setting streamer type 'mjpeg'.
Mar 4 20:52:45 octopi systemd[1]: streamer_select.service: Succeeded.
Mar 4 20:52:45 octopi systemd[1]: Started OctoPi streamer selector.
Mar 4 20:52:45 octopi raspi-config[393]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
Mar 4 20:52:45 octopi kernel: [ 10.069506] 8021q: 802.1Q VLAN Support v1.8
Mar 4 20:52:45 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Mar 4 20:52:45 octopi systemd[1]: Condition check resulted in FFMPEG HLS webcam streaming service being skipped.
Mar 4 20:52:45 octopi systemd[1]: Reached target Sound Card.
Mar 4 20:52:45 octopi raspi-config[393]: No. Switching to ondemand scaling governor.
Mar 4 20:52:45 octopi kernel: [ 10.105141] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
Mar 4 20:52:45 octopi avahi-daemon[388]: Successfully called chroot().
Mar 4 20:52:45 octopi avahi-daemon[388]: Successfully dropped remaining capabilities.
Mar 4 20:52:45 octopi wpa_supplicant[427]: Successfully initialized wpa_supplicant
Mar 4 20:52:45 octopi systemd[1]: Started Login Service.
Mar 4 20:52:45 octopi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Mar 4 20:52:45 octopi avahi-daemon[388]: No service file found in /etc/avahi/services.
Mar 4 20:52:45 octopi systemd[1]: Started dphys-swapfile - set up, mount/unmount, and delete a swap file.
Mar 4 20:52:45 octopi avahi-daemon[388]: Network interface enumeration completed.
Mar 4 20:52:45 octopi avahi-daemon[388]: Server startup complete. Host name is octopi.local. Local service cookie is 3236632471.
Mar 4 20:52:45 octopi systemd[1]: Started WPA supplicant.
Mar 4 20:52:45 octopi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Mar 4 20:52:45 octopi dhcpcd[400]: wlan0: starting wpa_supplicant
Mar 4 20:52:45 octopi root: Starting USB webcam
Mar 4 20:52:45 octopi dhcpcd-run-hooks[474]: wlan0: starting wpa_supplicant
Mar 4 20:52:45 octopi MJPG-streamer [475]: starting application
Mar 4 20:52:45 octopi MJPG-streamer [475]: MJPG Streamer Version: git rev: 5554f42c352ecfa7edaec6fc51e507afce605a34
Mar 4 20:52:45 octopi MJPG-streamer [475]: Using V4L2 device.: /dev/video0
Mar 4 20:52:45 octopi MJPG-streamer [475]: Desired Resolution: 640 x 480
Mar 4 20:52:45 octopi MJPG-streamer [475]: Frames Per Second.: 10
Mar 4 20:52:45 octopi MJPG-streamer [475]: Format............: JPEG
Mar 4 20:52:45 octopi MJPG-streamer [475]: TV-Norm...........: DEFAULT
Mar 4 20:52:45 octopi MJPG-streamer [475]: www-folder-path......: ./www-octopi/
Mar 4 20:52:45 octopi MJPG-streamer [475]: HTTP TCP port........: 8080
Mar 4 20:52:45 octopi MJPG-streamer [475]: HTTP Listen Address..: 127.0.0.1
Mar 4 20:52:45 octopi MJPG-streamer [475]: username:password....: disabled
Mar 4 20:52:45 octopi MJPG-streamer [475]: commands.............: disabled
Mar 4 20:52:45 octopi MJPG-streamer [475]: starting input plugin input_uvc.so
Mar 4 20:52:45 octopi MJPG-streamer [475]: starting output plugin: output_http.so (ID: 00)
Mar 4 20:52:45 octopi kernel: [ 10.409017] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
Mar 4 20:52:46 octopi dhcpcd[400]: wlan0: connected to Access Point `'
Mar 4 20:52:46 octopi dhcpcd[400]: eth0: waiting for carrier
Mar 4 20:52:46 octopi dhcpcd[400]: wlan0: waiting for carrier
Mar 4 20:52:46 octopi kernel: [ 10.700402] 8021q: adding VLAN 0 to HW filter on device eth0
Mar 4 20:52:46 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
Mar 4 20:52:48 octopi octoprint[372]: 2021-03-04 20:52:48,462 - octoprint.startup - INFO - ******************************************************************************
Mar 4 20:52:48 octopi octoprint[372]: 2021-03-04 20:52:48,464 - octoprint.startup - INFO - Starting OctoPrint 1.5.3
Mar 4 20:52:48 octopi octoprint[372]: 2021-03-04 20:52:48,464 - octoprint.startup - INFO - ******************************************************************************
Mar 4 20:52:49 octopi systemd[1]: systemd-rfkill.service: Succeeded.
Mar 4 20:52:51 octopi MJPG-streamer [475]: select() timeout
Mar 4 20:52:51 octopi MJPG-streamer [475]: cleaning up resources allocated by input thread
Mar 4 20:52:51 octopi dhcpcd[400]: wlan0: carrier acquired
Mar 4 20:52:51 octopi dhcpcd[400]: wlan0: connected to Access Point `TMmrCR'
Mar 4 20:52:51 octopi kernel: [ 16.436793] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Mar 4 20:52:52 octopi kernel: [ 16.918865] Bluetooth: Core ver 2.22
Mar 4 20:52:52 octopi kernel: [ 16.918988] NET: Registered protocol family 31
Mar 4 20:52:52 octopi kernel: [ 16.918999] Bluetooth: HCI device and connection manager initialized
Mar 4 20:52:52 octopi kernel: [ 16.919027] Bluetooth: HCI socket layer initialized
Mar 4 20:52:52 octopi kernel: [ 16.919043] Bluetooth: L2CAP socket layer initialized
Mar 4 20:52:52 octopi kernel: [ 16.919074] Bluetooth: SCO socket layer initialized
Mar 4 20:52:52 octopi btuart[373]: bcm43xx_init
Mar 4 20:52:52 octopi btuart[373]: Flash firmware /lib/firmware/brcm/BCM4345C0.hcd
Mar 4 20:52:52 octopi btuart[373]: Set BDADDR UART: b8:27:eb:ec:xx:xx
Mar 4 20:52:52 octopi btuart[373]: Set Controller UART speed to 3000000 bit/s
Mar 4 20:52:52 octopi kernel: [ 16.929401] Bluetooth: HCI UART driver ver 2.3
Mar 4 20:52:52 octopi kernel: [ 16.929420] Bluetooth: HCI UART protocol H4 registered
Mar 4 20:52:52 octopi kernel: [ 16.929527] Bluetooth: HCI UART protocol Three-wire (H5) registered
Mar 4 20:52:52 octopi kernel: [ 16.929746] Bluetooth: HCI UART protocol Broadcom registered
Mar 4 20:52:52 octopi btuart[373]: Device setup complete
Mar 4 20:52:52 octopi systemd[1]: Started Configure Bluetooth Modems connected by UART.
Mar 4 20:52:52 octopi systemd[1]: Created slice system-bthelper.slice.
Mar 4 20:52:52 octopi systemd[1]: Starting Bluetooth service...
Mar 4 20:52:52 octopi systemd[1]: Starting Load/Save RF Kill Switch Status...
Mar 4 20:52:52 octopi systemd[1]: Started Load/Save RF Kill Switch Status.
Mar 4 20:52:52 octopi bluetoothd[505]: Bluetooth daemon 5.50
Mar 4 20:52:52 octopi systemd[1]: Started Bluetooth service.
Mar 4 20:52:52 octopi systemd[1]: Started Raspberry Pi bluetooth helper.
Mar 4 20:52:52 octopi bluetoothd[505]: Starting SDP server
Mar 4 20:52:52 octopi systemd[1]: Reached target Bluetooth.
Mar 4 20:52:52 octopi kernel: [ 17.175004] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Mar 4 20:52:52 octopi kernel: [ 17.175017] Bluetooth: BNEP filters: protocol multicast
Mar 4 20:52:52 octopi kernel: [ 17.175035] Bluetooth: BNEP socket layer initialized
Mar 4 20:52:52 octopi dbus-daemon[426]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.5' (uid=0 pid=505 comm="/usr/lib/bluetooth/bluetoothd ")
Mar 4 20:52:52 octopi bluetoothd[505]: Bluetooth management interface 1.18 initialized
Mar 4 20:52:52 octopi bluetoothd[505]: Sap driver initialization failed.
Mar 4 20:52:52 octopi bluetoothd[505]: sap-server: Operation not permitted (1)
Mar 4 20:52:52 octopi bthelper[507]: Raspberry Pi BDADDR already set
Mar 4 20:52:52 octopi systemd[1]: Starting Hostname Service...
Mar 4 20:52:52 octopi bluetoothd[505]: Failed to set privacy: Rejected (0x0b)
Mar 4 20:52:52 octopi bthelper[507]: Changing power off succeeded
Mar 4 20:52:52 octopi dbus-daemon[426]: [system] Successfully activated service 'org.freedesktop.hostname1'
Mar 4 20:52:52 octopi systemd[1]: Started Hostname Service.
Mar 4 20:52:52 octopi bthelper[507]: Changing power on succeeded
Mar 4 20:52:52 octopi systemd[1]: bthelper@hci0.service: Succeeded.
Mar 4 20:52:55 octopi octoprint[372]: 2021-03-04 20:52:55,009 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: offline
Mar 4 20:52:55 octopi octoprint[372]: 2021-03-04 20:52:55,010 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:53 is not working
Mar 4 20:52:55 octopi octoprint[372]: 2021-03-04 20:52:55,010 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is not working
Mar 4 20:52:55 octopi octoprint[372]: 2021-03-04 20:52:55,020 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
Mar 4 20:52:55 octopi octoprint[372]: 2021-03-04 20:52:55,138 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
Mar 4 20:52:56 octopi octoprint[372]: 2021-03-04 20:52:56,843 - octoprint.startup - INFO - Added settings overlay from plugin firmware_check
Mar 4 20:52:56 octopi octoprint[372]: 2021-03-04 20:52:56,845 - octoprint.plugin.core - INFO - Found 17 plugin(s) providing 17 mixin implementations, 34 hook handlers
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,009 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,035 - octoprint.server - INFO - Intermediary server started
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,064 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,066 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,070 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: "Need(method='role', value='plugin_action_command_notification_show')")
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,070 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: "Need(method='role', value='plugin_action_command_notification_clear')")
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,071 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: "Need(method='role', value='plugin_action_command_prompt_interact')")
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,071 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: "Need(method='role', value='plugin_announcements_read')")
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,072 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: "Need(method='role', value='plugin_announcements_read'), Need(method='role', value='plugin_announcements_manage')")
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,073 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: "Need(method='role', value='plugin_appkeys_admin')")
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,073 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: "Need(method='role', value='plugin_backup_access')")
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,074 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: "Need(method='role', value='plugin_firmware_check_display')")
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,074 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: "Need(method='role', value='plugin_logging_manage')")
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,075 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: "Need(method='role', value='plugin_pi_support_check')")
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,075 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: "Need(method='role', value='plugin_pluginmanager_manage')")
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,081 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: "Need(method='role', value='plugin_pluginmanager_manage'), Need(method='role', value='plugin_pluginmanager_install')")
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,083 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: "Need(method='role', value='plugin_softwareupdate_check')")
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,084 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: "Need(method='role', value='plugin_softwareupdate_update')")
Mar 4 20:52:57 octopi octoprint[372]: 2021-03-04 20:52:57,085 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: "Need(method='role', value='plugin_softwareupdate_configure')")
Mar 4 20:52:57 octopi dhcpcd[400]: wlan0: leased 10.20.30.125 for 86400 seconds
Mar 4 20:52:57 octopi avahi-daemon[388]: Joining mDNS multicast group on interface wlan0.IPv4 with address 10.20.30.125.
Mar 4 20:52:57 octopi avahi-daemon[388]: New relevant interface wlan0.IPv4 for mDNS.
Mar 4 20:52:57 octopi avahi-daemon[388]: Registering new address record for 10.20.30.125 on wlan0.IPv4.
Mar 4 20:52:57 octopi dhcpcd[400]: wlan0: adding route to .....
Mar 4 20:52:57 octopi dhcpcd[400]: wlan0: adding default route via ....
Mar 4 20:52:57 octopi dhcpcd[400]: forked to background, child pid 588
Mar 4 20:52:57 octopi systemd[1]: Started dhcpcd on all interfaces.
Mar 4 20:52:57 octopi systemd[1]: Reached target Network.
Mar 4 20:52:57 octopi systemd[1]: Starting Permit User Sessions...
Mar 4 20:52:57 octopi systemd[1]: Starting OpenBSD Secure Shell server...
Mar 4 20:52:57 octopi systemd[1]: Starting HAProxy Load Balancer...
Mar 4 20:52:57 octopi systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
Mar 4 20:52:57 octopi systemd[1]: Condition check resulted in NGINX server for serving HLS and JPEG frames being skipped.
Mar 4 20:52:57 octopi systemd[1]: Starting /etc/rc.local Compatibility...
Mar 4 20:52:57 octopi systemd[1]: Started Permit User Sessions.
Mar 4 20:52:57 octopi systemd[1]: systemd-rfkill.service: Succeeded.
Mar 4 20:52:57 octopi systemd[1]: Started OpenBSD Secure Shell server.
Mar 4 20:52:57 octopi systemd[1]: Started HAProxy Load Balancer.
Mar 4 20:52:57 octopi systemd[1]: Started /etc/rc.local Compatibility.
Mar 4 20:52:57 octopi systemd[1]: Started Getty on tty1.
Mar 4 20:52:57 octopi systemd[1]: Reached target Login Prompts.
Mar 4 20:52:57 octopi systemd[1]: Reached target Multi-User System.
Mar 4 20:52:57 octopi systemd[1]: Reached target Graphical Interface.
Mar 4 20:52:57 octopi systemd[1]: Starting Update UTMP about System Runlevel Changes...
Mar 4 20:52:57 octopi systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
Mar 4 20:52:57 octopi systemd[1]: Started Update UTMP about System Runlevel Changes.
Mar 4 20:52:57 octopi systemd[1]: Startup finished in 4.055s (kernel) + 18.451s (userspace) = 22.506s.
Mar 4 20:52:58 octopi octoprint[372]: 2021-03-04 20:52:58,479 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
Mar 4 20:52:59 octopi octoprint[372]: 2021-03-04 20:52:59,326 - octoprint.util.pip - INFO - Version of pip is 20.3.3
Mar 4 20:52:59 octopi octoprint[372]: 2021-03-04 20:52:59,328 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
Mar 4 20:52:59 octopi octoprint[372]: 2021-03-04 20:52:59,329 - octoprint.util.pip - INFO - ==> pip ok -> yes
Mar 4 20:52:59 octopi octoprint[372]: 2021-03-04 20:52:59,397 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
Mar 4 20:52:59 octopi octoprint[372]: 2021-03-04 20:52:59,422 - octoprint.plugin.core - INFO - Initialized 17 plugin implementation(s)
Mar 4 20:52:59 octopi octoprint[372]: 2021-03-04 20:52:59,437 - octoprint.plugin.core - INFO - 17 plugin(s) registered with the system:
Mar 4 20:52:59 octopi octoprint[372]: | Action Command Notification Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_notification
Mar 4 20:52:59 octopi octoprint[372]: | Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_prompt
Mar 4 20:52:59 octopi octoprint[372]: | Announcement Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/announcements
Mar 4 20:52:59 octopi octoprint[372]: | Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/tracking
Mar 4 20:52:59 octopi octoprint[372]: | Application Keys Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/appkeys
Mar 4 20:52:59 octopi octoprint[372]: | Backup & Restore (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/backup
Mar 4 20:52:59 octopi octoprint[372]: | Core Wizard (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/corewizard
Mar 4 20:52:59 octopi octoprint[372]: | Discovery (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/discovery
Mar 4 20:52:59 octopi octoprint[372]: | Error Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/errortracking
Mar 4 20:52:59 octopi octoprint[372]: | File Check (2021.2.23) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_file_check
Mar 4 20:52:59 octopi octoprint[372]: | Firmware Check (2021.2.4) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_firmware_check
Mar 4 20:52:59 octopi octoprint[372]: | GCode Viewer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/gcodeviewer
Mar 4 20:52:59 octopi octoprint[372]: | Logging (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/logging
Mar 4 20:52:59 octopi octoprint[372]: | Pi Support Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pi_support
Mar 4 20:52:59 octopi octoprint[372]: | Plugin Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pluginmanager
Mar 4 20:52:59 octopi octoprint[372]: | Software Update (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate
Mar 4 20:52:59 octopi octoprint[372]: | Virtual Printer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/virtual_printer
Mar 4 20:52:59 octopi octoprint[372]: Prefix legend: ! = disabled, # = blacklisted, * = incompatible
Mar 4 20:52:59 octopi octoprint[372]: 2021-03-04 20:52:59,468 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
Mar 4 20:52:59 octopi octoprint[372]: | hardware:
Mar 4 20:52:59 octopi octoprint[372]: | cores: 4
Mar 4 20:52:59 octopi octoprint[372]: | freq: 1400.0
Mar 4 20:52:59 octopi octoprint[372]: | ram: 915058688
Mar 4 20:52:59 octopi octoprint[372]: | os:
Mar 4 20:52:59 octopi octoprint[372]: | bits: 32
Mar 4 20:52:59 octopi octoprint[372]: | id: linux
Mar 4 20:52:59 octopi octoprint[372]: | platform: linux
Mar 4 20:52:59 octopi octoprint[372]: | plugins:
Mar 4 20:52:59 octopi octoprint[372]: | pi_support:
Mar 4 20:52:59 octopi octoprint[372]: | model: Raspberry Pi 3 Model B Plus Rev 1.3
Mar 4 20:52:59 octopi octoprint[372]: | octopi_version: 0.18.0
Mar 4 20:52:59 octopi octoprint[372]: | throttle_state: '0x0'
Mar 4 20:52:59 octopi octoprint[372]: | python:
Mar 4 20:52:59 octopi octoprint[372]: | pip: 20.3.3
Mar 4 20:52:59 octopi octoprint[372]: | version: 3.7.3
Mar 4 20:52:59 octopi octoprint[372]: | virtualenv: /home/pi/oprint
Mar 4 20:52:59 octopi octoprint[372]: 2021-03-04 20:52:59,480 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
Mar 4 20:52:59 octopi octoprint[372]: 2021-03-04 20:52:59,499 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
Mar 4 20:53:00 octopi octoprint[372]: 2021-03-04 20:53:00,257 - octoprint.server - INFO - Shutting down intermediary server...
Mar 4 20:53:00 octopi octoprint[372]: 2021-03-04 20:53:00,545 - octoprint.server - INFO - Intermediary server shut down
dmesg (relevant info):
[ 6.936981] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.939611] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 6.939641] [vc_sm_connected_init]: start
[ 6.948940] mc: Linux media interface: v0.10
[ 6.951119] [vc_sm_connected_init]: installed successfully
[ 7.078190] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.090181] videodev: Linux video capture interface: v2.00
[ 7.101160] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 7.118734] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.118742] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.121647] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.133811] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.138431] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.142702] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.146718] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 7.147344] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 7.148147] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 7.151080] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 7.151138] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 7.151179] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 7.151215] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 7.151250] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 7.151625] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 7.151634] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 7.151680] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 7.169540] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 7.169613] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 7.472734] usbcore: registered new interface driver usbserial_generic
[ 7.472820] usbserial: USB Serial support registered for generic
[ 7.477352] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.487342] usbcore: registered new interface driver ftdi_sio
[ 7.487436] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 7.487789] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
[ 7.487988] usb 1-1.3: Detected FT232RL
[ 7.499037] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
[ 7.608412] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 7.700114] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 7.710905] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.712645] usbcore: registered new interface driver brcmfmac
[ 7.752583] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt failed with error -2
vcgencmd:
pi@octopi:~ $ vcgencmd get_camera
supported=1 detected=1
OctoPrint: Version 1.5.3
OctoPi: 0.18.0
Pi: Raspberry Pi 3 Model B+
** Other Info
When the Pi boots up, I do see the red light on the picam light up then go off. I do not see it light up again.
Thank you all for your help!
