After installing the 1.10.0 upgrade, my Z-axis will not work correctly. the z-offset parameter in the [bltouch] section pf printer.cfg has been commented out but the program, and when it thinks z is homed, it is actually about.1mm too high, and nothing sticks to the bed.
Tried putting a z-offset in the slicer, but then the printer tries to move to a negative Z and crashes. Tried different tricks in the gcode, but my slicer has so many G92 codes it is useless.
no
Octoprint 1.10.0
Octopi 1.0.0
Browser Safari
Python 3.9.2 on Mac
Printer Creality Ender 4.2.7, Printhead Creality Sprite with BLTouch
Klipper on Raspberry Pi (Can't find version #)
The 1.10.0 update was for OctoPrint. Your 'printer.cfg' sounds like Klipper configuration, which is separate from OctoPrint and will not have been changed by updating OctoPrint.
It sounds like you need this z offset setting to correctly calibrate your printer, so that the BL touch knows how far away from the actual nozzle height it is. I'd suggest un-commenting it and setting it correctly. If you need more help with Klipper I'd suggest a Klipper forum as I don't know the details here.
Thanks, I'll check the Klipper forum. So things like Mxxx commands being deprecated is being done by Klipper, not Octoprint. Since I never interact with Klipper directly (except editing printer.conf) I just assumed it was the Octoprint update that was the culprit.
