Can't access LAN Android IP Webcam for stream, snapshot OK
I set up OctoPrint in a docker container, and everything was working great. I got it connected to the printer without any problem.
I have an Android phone running IP Webcam by Pavel Khlebovich and I can access that from my PC just fine using http://ip:8080 for the web interface, or http://ip:8080/video for stream or http://ip:8080/photo.jpg for a snapshot.
I found guides that seemed to indicate this should work fine inside octoprint, but when I put in the stream URL the test window shows a broken image link and says it isn't working, but the snapshot test works fine.
If I right-click on that broken image link in the browser and say open in a new tab it opens up http://ip:8080/video which works fine and shows me the video feed.
I don't understand why it isn't working in octoprint and I'm not sure where else to look to debug. I did open a shell inside the docker container and I can access the webcam from there (at least ping/netcat to it).
Not sure what else to test. The longer term plan is to put a USB webcam on it, but I thought I would try to use what I have first but it has been a little frustrating because of this little bump in the road.
Using netcat inside the docker container to that IP address gives the following:
nc -v -n IPADDR 8080
(UNKNOWN) [IPADDR] 8080 (http-alt) open
GET /video HTTP/1.0
HTTP/1.1 200 OK
Connection: close
Server: IP Webcam Server 0.4
Cache-Control: no-store, no-cache, must-revalidate, pre-check=0, post-check=0, max-age=0
Pragma: no-cache
Expires: -1
Access-Control-Allow-Origin: *
Content-Type: multipart/x-mixed-replace;boundary=Ba4oTvQMY8ew04N8dcnM
--Ba4oTvQMY8ew04N8dcnM
Content-Type: image/jpeg
Content-Length: 582423
????JFIF??C??C??"??
I installed OctoCam instead, and stream works, but now I can't figure out how to get the snapshot to work. Looking for the right URL format... :wink: [add /?snapshot to the URL]
I tried the ?snapshot on the end of the URL for OctoCam, and it works in a browser but not in Octoprint. Go figure, so it is working exactly the opposite of the IP Camera for me. LoL
I added this plugin Webcam Iframe and finally I could view my video in the control tab. Test button not working but I'm happy with seeing it in the control tab.
Try http://[ip] [port] / H264.sdp or h264_ulaw.sdp
