New to Pi & Octoprint so please excuse any inaccurate terminology.
Equipment:
Windows 10
2020-12-02-octopi-buster-armhf-lite-0.18.0.img
RasPi 3b+ (Rev3)
Genuine SanDisk Ultra 64gb
Ender 3 Max
BalenaEtcher
A brief description of my issue(s) is;
I downloaded & installed Octoprint yesterday, flashed it with Balena on to a genuine 64gb SanDisk Ultra and followed the steps to get it up and running, up to and including changing the host name & password and logging into the Octoprint dashboard through the new host name. I had no issues with these steps but I noticed that Octoprint wasn’t recognising my printer or saving my printer settings. When i went into the printer settings to see why not and add a print profile for the Ender 3 Max it wouldn't save and just reverted back to the Default printer.
I did a bit of research as to why this might be happening on the forum and I did try rebooting in safe mode to see if that would help the printer issue beforehand, as i noticed that the safe mode was marked as false, but it didn't make any difference. A couple of answers suggested that the SD card might have been the issue. Therefore, today I took the SD card out, deleted everything, reformatted it to FAT32 again in case there was something left on there that i couldn't see and restarted the whole process with a fresh download of the image. I uncommented the 4 lines on 27, 28, 29 & 30, and added my SSID & password on 28 & 29 using notepad++ as i had done previously and saved before exiting, but now when try to access it through the command ssh pi@octopi.local I get the message below. I've tried to give as much information as i can but if ive missed anything please let me know.
H:>ssh pi@octopi.local
@ WARNING: POSSIBLE DNS SPOOFING DETECTED! @
The ECDSA host key for octopi.local has changed,
and the key for the corresponding IP address fe80::f398:9c32:b896:6125%26
is unknown. This could either mean that
DNS SPOOFING is happening or the IP address for the host
and its host key have changed at the same time.
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the ECDSA key sent by the remote host is
SHA256:Hyk4RhlsfUoPKoSjJFDaPDOsQGjpBs82Iw+dQ7xhKHM.
Please contact your system administrator.
Add correct host key in C:\Users\SSmith/.ssh/known_hosts to get rid of this message.
Offending ECDSA key in C:\Users\SSmith/.ssh/known_hosts:1
ECDSA host key for octopi.local has changed and you have requested strict checking.
Host key verification failed.
