I can no longer access my octoprint instance from my desktop after changing my local subnet. The Octopi works as normal with all added plugins etc, but I can no longer access it from my desktop. Not sure why, pw hasn't been changed in over a year. But everything is functional. I can access it via ssh fine, and have done a full .img back and tried restoring. No dice. Tried deleting the users.yaml/replacing it with a fresh one. The "first start" string works to no avail. Tried all the "reset user password, search results with no results)
Logs (octoprint.log
, serial.log
or output on terminal tab at a minimum, browser error console if UI issue ... no logs, no support!)
2020-02-16 15:24:13,181 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-02-16 15:24:13,217 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2020-02-16 15:24:13,217 - octoprint.server - INFO - OctoPrint 1.3.12
2020-02-16 15:24:13,229 - octoprint.plugin.core - INFO - 31 plugin(s) registered with the system:
| ABL Expert Plugin (0.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_ABL_Expert
| BLTouch Plugin (0.3.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_BLTouch
| Change Filament Plugin (0.3.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_Change_Filament
| Dashboard (1.11.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_dashboard
| DiscordRemote (2.51.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_discordremote
| DisplayLayerProgress Plugin (1.17.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_DisplayLayerProgress
| Exclude Region (0.2.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_excluderegion
| Fullscreen Plugin (0.0.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_fullscreen
| MultiCam (0.2.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_multicam
| MultipleUpload Plugin (1.0.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_MultipleUpload
| Octolapse (0.3.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octolapse
| OctoPrint Anywhere (1.0.21) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_anywhere
| OctoRant (1.2.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octorant
| Preheat Button (0.4.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_preheat
| PrintTimeGenius Plugin (2.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_PrintTimeGenius
| Themeify (1.2.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_themeify
2020-02-16 15:24:13,257 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 917016576
| os:
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 3 Model B Plus Rev 1.3
Ender 3 Pro (SKR v1.3), been using this for a year. no problems. Multicam is functional. not sure what the deal is.
