Including adding the above line in custom configuration in the lower right corner in your screenshot?
If so and that also didn't help it then I don't know how to help you here. I haven't heard back from Frenck but since found that the nginx configuration interface that is behind this HA add-on is this:
I haven't been able to figure out if that supports a config export though. As I said, without seeing how your nginx instance is actually configured, this all is leading nowhere sadly. All I can tell you is that it works just as it should on my end with nginx in front, as long as it's configured as shown in the linked examples.
The strange thing is, that this is happened after upgrade octoprint. But I understand all you wrote, I will use no SSL connection, because I need to control octoprint from outside of my network. Not safe, but have no another option
chagned too (in lower light corner window of my screenshot as foosel said) and nothing changed still the same. @octojam - are you using nginx addon in home assistant too?
Just upgraded to the current nginx 1.19.1 to rule out it was a difference in behaviour between what I still had on this dev machine (1.13.something) and current versions.
Still no reproduction, it's behaving like it should with:
My friend has exactly same experience.. he has standalone nginx on rpi2 and has no problem with 1.4.2 version ;-/
this is somewhere between earth, sky and nginx addon
After further investigation I’ve managed to narrow it down to the missing X-Scheme header (as @foosel pointed out much earlier). Unfortunately there isn’t an easy way to add this to config managed by Nginx Proxy Manager, so we might need to try and get something merged into Nginx Proxy Manager upstream.
I assume then that the change in 1.4.2 is the enforcement of scheme matching on the Origin header.
I'm pretty sure you are right in your assumption that it's the origin check that fails, as that's about the only place I can see a 403 being generated on websocket connection.
And that also saw a fix in 1.4.1/1.4.2:
I just debugged into this and I'm only seeing https as scheme there for both regular requests as well as secure websocket connections. I'm wondering if for SOME reason some of you are getting a wss scheme there, which would make this mismatch.
If it is the origin check, you could check if enabling CORS under Settings > API makes it work, as that will bypass the origin check on the web socket as well.
Edit: I've just pushed
which translates wss/ws into https/http for the origin check. If anyone of you currently being able to reproduce this problem (I still can't) would be able to test the maintenance branch and check if it's gone on that, that would help a lot.
I'm willing to try this out as I have the same issue, but I seem to have issues with the steps to switch to the maintenance branch outlined here:
pi@octopi:~/OctoPrint $ source ~/oprint/bin/activate
(oprint) pi@octopi:~/OctoPrint $ git fetch
fatal: not a git repository (or any of the parent directories): .git
Have you run the add OctoPrint checkout script mentioned at the top of the FAQ post? OctoPi does not have the git repo by default, just the pip packages. Try running ~/scripts/add-octoprint-checkout, then the git repo should be there?
I've just tried the maintenance release and unfortunately I'm still getting the same error.
OctoPrint 1.5.0.dev126+g641f27af3
Python 2.7.16
OctoPi 0.17.0
octoprint.log
2020-08-17 18:42:55,200 - octoprint.server.preemptive_cache - INFO - ... done in 0.20s
2020-08-17 18:42:56,675 - tornado.access - WARNING - 403 GET /sockjs/920/dqje4skz/websocket (::ffff:10.10.10.11) 2.39ms
2020-08-17 18:42:56,696 - octoprint.server.util.sockjs - INFO - New connection from client: 10.10.10.254
2020-08-17 18:42:59,380 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:10.10.10.20
2020-08-17 18:42:59,436 - octoprint.server.util.flask - INFO - Passively logging in user username from ::ffff:10.10.10.20
2020-08-17 18:42:59,441 - octoprint.access.users - INFO - Logged in user: username
2020-08-17 18:43:04,356 - octoprint.server.util.sockjs - INFO - User username logged in on the socket from client ::ffff:10.10.10.20
2020-08-17 18:43:33,277 - tornado.access - WARNING - 403 GET /sockjs/128/o3rfoud1/websocket (::ffff:10.10.10.11) 2.36ms
2020-08-17 18:43:33,295 - octoprint.server.util.sockjs - INFO - New connection from client: 10.10.10.254
2020-08-17 18:44:49,549 - tornado.access - WARNING - 403 GET /sockjs/888/ilbtquzy/websocket (::ffff:10.10.10.11) 2.25ms
2020-08-17 18:44:49,565 - octoprint.server.util.sockjs - INFO - New connection from client: 10.10.10.254
2020-08-17 18:46:26,373 - tornado.access - WARNING - 403 GET /sockjs/701/nnaqx2ng/websocket (::ffff:10.10.10.11) 3.99ms
2020-08-17 18:46:27,285 - octoprint.server.util.sockjs - INFO - New connection from client: 10.10.10.254
2020-08-17 18:46:40,740 - tornado.access - WARNING - 403 GET /sockjs/526/jw3rgbhk/websocket (::ffff:10.10.10.11) 3.97ms
2020-08-17 18:46:40,766 - octoprint.server.util.sockjs - INFO - New connection from client: 10.10.10.254
2020-08-17 18:46:43,937 - octoprint.access.users - INFO - Logged in user: username
2020-08-17 18:46:43,944 - octoprint.server.api - INFO - Actively logging in user username from 10.10.10.254
2020-08-17 18:46:45,352 - tornado.access - WARNING - 404 GET /favicon.ico (::ffff:10.10.10.11) 19.78ms
2020-08-17 18:46:45,384 - tornado.access - WARNING - 403 GET /sockjs/232/i5upyyhe/websocket (::ffff:10.10.10.11) 3.35ms
2020-08-17 18:46:45,469 - octoprint.server.util.sockjs - INFO - New connection from client: 10.10.10.254
Same error in both Chrome and Safari. I've also tried with the different proxy_set_header options in nginx but same issue. In 1.4.1 I was running my octopi proxy host with out of the box settings fine.
