Logitech c270
I'm running OctoPrint on an Intel Nuc, set up with Ubuntu Server 22.04 LTS, as such I've been installing everything manually, including mjpg-streamer. I have everything working, but when I start the camera up it defaults to a resolution of 640x480 and frames per second set to -1:
isaacprint@isaacprintserver:~/mjpg-streamer/mjpg-streamer-experimental$ sudo ./mjpg_streamer -i "./input_uvc.so" -o "./output_http.so"
[sudo] password for isaacprint:
MJPG Streamer Version: git rev: 310b29f4a94c46652b20c4b7b6e5cf24e532af39
i: Frames Per Second.: -1
i: Format............: JPEG
o: www-folder-path......: disabled
o: HTTP Listen Address..: (null)
o: commands.............: enabled
If I try to change this, using the -r and/or -f arguments, it fails and suggests that those options are not available:
isaacprint@isaacprintserver:~/mjpg-streamer/mjpg-streamer-experimental$ sudo ./mjpg_streamer -i "./input_uvc.so" -r 1280x720 -f 15 -o "./output_http.so"
./mjpg_streamer: invalid option -- 'r'
Usage: ./mjpg_streamer
-i | --input "<input-plugin.so> [parameters]"
-o | --output "<output-plugin.so> [parameters]"
[-h | --help ]........: display this help
[-v | --version ].....: display version information
[-b | --background]...: fork to the background, daemon mode
Example #1:
To open an UVC webcam "/dev/video1" and stream it via HTTP:
./mjpg_streamer -i "input_uvc.so -d /dev/video1" -o "output_http.so"
Example #2:
To open an UVC webcam and stream via HTTP port 8090:
./mjpg_streamer -i "input_uvc.so" -o "output_http.so -p 8090"
Example #3:
To get help for a certain input plugin:
./mjpg_streamer -i "input_uvc.so --help"
In case the modules (=plugins) can not be found:
* Set the default search path for the modules with:
export LD_LIBRARY_PATH=/path/to/plugins,
* or put the plugins into the "/lib/" or "/usr/lib" folder,
* or instead of just providing the plugin file name, use a complete
path and filename:
./mjpg_streamer -i "/path/to/modules/input_uvc.so"
As shown, the only flags it lists as available are -i and -o
I googled the problem, but every solution I saw referenced octopi.txt, which I don't have due to a manual linux installation on a non-Pi pc.
Intel NUC, Ubuntu Server 22.04 LTS, OctoPrint version is 1.8.6, Python version 3.10.6, mjpg streamer version 310b29f4a94c46652b20c4b7b6e5cf24e532af39
