Raspberry Pi 4B running current OctoPrint won't stay connected to my computer. Restarting my PC lets me connect again for about a minute.
I've done a good amount problem solving to get it as good as this. My Raspberry is plugged into a recommended power supply. I've swapped cables over and over to find one that allows me to pass data from my Raspberry to the 3D printer (Ender 3 V2), now found one that works. Restarting the Raspberry doesn't work. Restarting the printer doesn't work. Disconnecting the printer doesn't work. Restarting everything in different orders doesn't work. Keeping the printer plugged in, or keeping it unplugged through the various processes of restarting everything doesn't help.
Right after restarting the PC, I can find the Raspberry through octopi.local, and for the short time (a few minutes) it is working, everything seems to work.
No. Also, I don't know how without being able to connect to the Pi for longer.
Ok, I've tried lots of things but nothing has fixed the problem.
I got the Pi on it's own monitor, confirmed it was loading properly and got the IP address.
I can't connect using that IP address at all. Not for a moment.
Connecting via octopi.local still works for max of a few minutes after restarting my PC.
've tried on a different network with the same results.
Biggest progress! I accessed octopi.local on a different PC, and it seems to work normally.
Bottom line, I've narrowed the problem to my PC. Are there setting on my PC that could be blocking access that might not take effect for a few minutes after a restart?
