I have been using OctoPi happily for the past 3 weeks. Suddenly one day it would not connect to the printer and I get the dreaded Offline (Error: No more candidates to test, and no working port/baudrate combination detected.) error.
In the serial log below I see a line:
2021-03-06 17:58:32,565 - Performing autodetection with 0 port/baudrate candidates:
But from other serial logs I think the 0 is the issue??
I have started with a fresh install of Octopi. Installed the 12v to 5v 3amp buck that I have been meaning to fit and tried a variety of other cables. I have also tried deleting the ttyAMA0 as suggested on another thread.
Yes. It made no difference.
Complete Logs
Octoprint Log:
2021-03-06 17:45:50,262 - octoprint.startup - INFO - Starting OctoPrint 1.5.2
2021-03-06 17:45:50,263 - octoprint.startup - INFO - ******************************************************************************
2021-03-06 17:45:56,853 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: offline
2021-03-06 17:45:56,853 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:53 is not working
2021-03-06 17:45:56,854 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is not working
2021-03-06 17:45:56,864 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
2021-03-06 17:45:59,830 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2021-03-06 17:46:01,888 - octoprint.plugin.core - INFO - Found 17 plugin(s) providing 17 mixin implementations, 34 hook handlers
2021-03-06 17:46:02,054 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2021-03-06 17:46:02,079 - octoprint.server - INFO - Intermediary server started
2021-03-06 17:46:02,115 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2021-03-06 17:46:02,117 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2021-03-06 17:46:02,121 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: "Need(method='role', value='plugin_action_command_notification_show')")
2021-03-06 17:46:02,122 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: "Need(method='role', value='plugin_action_command_notification_clear')")
2021-03-06 17:46:02,122 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: "Need(method='role', value='plugin_action_command_prompt_interact')")
2021-03-06 17:46:02,123 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: "Need(method='role', value='plugin_announcements_read')")
2021-03-06 17:46:02,124 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: "Need(method='role', value='plugin_announcements_manage'), Need(method='role', value='plugin_announcements_read')")
2021-03-06 17:46:02,125 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: "Need(method='role', value='plugin_appkeys_admin')")
2021-03-06 17:46:02,126 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: "Need(method='role', value='plugin_backup_access')")
2021-03-06 17:46:02,127 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: "Need(method='role', value='plugin_firmware_check_display')")
2021-03-06 17:46:02,128 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: "Need(method='role', value='plugin_logging_manage')")
2021-03-06 17:46:02,133 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: "Need(method='role', value='plugin_pi_support_check')")
2021-03-06 17:46:02,134 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: "Need(method='role', value='plugin_pluginmanager_manage')")
2021-03-06 17:46:02,136 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: "Need(method='role', value='plugin_pluginmanager_manage'), Need(method='role', value='plugin_pluginmanager_install')")
2021-03-06 17:46:02,138 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: "Need(method='role', value='plugin_softwareupdate_check')")
2021-03-06 17:46:02,139 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: "Need(method='role', value='plugin_softwareupdate_update')")
2021-03-06 17:46:02,141 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: "Need(method='role', value='plugin_softwareupdate_configure')")
2021-03-06 17:46:03,271 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2021-03-06 17:46:04,119 - octoprint.util.pip - INFO - Version of pip is 20.3.3
2021-03-06 17:46:04,121 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-03-06 17:46:04,122 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-03-06 17:46:04,190 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2021-03-06 17:46:04,212 - octoprint.plugin.core - INFO - Initialized 17 plugin implementation(s)
2021-03-06 17:46:04,225 - octoprint.plugin.core - INFO - 17 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_notification
| Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_prompt
| Announcement Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/announcements
| Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/tracking
| Application Keys Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/appkeys
| Backup & Restore (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/backup
| Core Wizard (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/corewizard
| Discovery (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/discovery
| Error Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/errortracking
| File Check (2020.8.7) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_file_check
| Firmware Check (2020.9.23) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_firmware_check
| GCode Viewer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/gcodeviewer
| Logging (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/logging
| Pi Support Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pi_support
| Plugin Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pluginmanager
| Software Update (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate
| Virtual Printer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/virtual_printer
2021-03-06 17:46:04,256 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 915718144
| os:
| bits: 32
| platform: linux
| plugins:
| pi_support:
| model: Raspberry Pi 3 Model B Plus Rev 1.3
| octopi_version: 0.18.0
| throttle_state: '0x0'
| python:
| pip: 20.3.3
| version: 3.7.3
| virtualenv: /home/pi/oprint
2021-03-06 17:46:04,269 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2021-03-06 17:46:04,287 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2021-03-06 17:46:05,097 - octoprint.server - INFO - Shutting down intermediary server...
2021-03-06 17:46:05,593 - octoprint.server - INFO - Intermediary server shut down
2021-03-06 17:46:05,595 - octoprint.events - INFO - Processing startup event, this is our first event
2021-03-06 17:46:05,596 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2021-03-06 17:46:05,600 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2021-03-06 17:46:05,603 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2021-03-06 17:46:05,605 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2021-03-06 17:46:05,608 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2021-03-06 17:46:06,422 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on cr10._http._tcp.local.' for _http._tcp.local.
2021-03-06 17:46:07,237 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on cr10._octoprint._tcp.local.' for _octoprint._tcp.local.
2021-03-06 17:46:07,249 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on cr10 for SSDP
2021-03-06 17:46:07,264 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2021-03-06 17:46:07,312 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2021-03-06 17:46:08,270 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2021-03-06 17:46:08,276 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-03-06 17:46:08,307 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-03-06 17:46:08,381 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 11.6GB. That is considered sufficient for updating.
2021-03-06 17:46:08,382 - octoprint.plugins.softwareupdate - INFO - Not fetching check overlays, we are offline
2021-03-06 17:46:09,067 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2021-03-06 17:46:09,769 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2021-03-06 17:46:09,888 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2021-03-06 17:46:11,549 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2021-03-06 17:46:11,683 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2021-03-06 17:46:11,685 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-03-06 17:46:11,685 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-03-06 17:46:11,715 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2021-03-06 17:46:11,849 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'http://192.168.0.20/', 'path': '/', 'query_string': 'l10n=en'}
2021-03-06 17:46:11,979 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 10}
2021-03-06 17:46:13,304 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {'version': '1.5.2', 'os': 'linux', 'bits': 32, 'python': '3.7.3', 'pip': '20.3.3', 'cores': 4, 'freq': 1400.0, 'ram': 915718144, 'pi_model': 'Raspberry Pi 3 Model B Plus Rev 1.3', 'octopi_version': '0.18.0', 'plugins': ''}
2021-03-06 17:46:13,626 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {'version': '1.5.2', 'os': 'linux', 'bits': 32, 'python': '3.7.3', 'pip': '20.3.3', 'cores': 4, 'freq': 1400.0, 'ram': 915718144, 'pi_model': 'Raspberry Pi 3 Model B Plus Rev 1.3', 'octopi_version': '0.18.0'}
2021-03-06 17:48:40,102 - octoprint.server.preemptive_cache - INFO - ... done in 10.77s
2021-03-06 17:48:40,832 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.11
2021-03-06 17:48:41,134 - tornado.access - WARNING - 403 GET /api/settings (::ffff:192.168.0.11) 128.43ms
2021-03-06 17:48:41,299 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.0.11
2021-03-06 17:48:41,741 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.11
2021-03-06 17:48:44,761 - octoprint.access.users - INFO - Logged in user: aerotec
2021-03-06 17:48:44,765 - octoprint.server.api - INFO - Actively logging in user aerotec from ::ffff:192.168.0.11
2021-03-06 17:48:44,834 - octoprint.server.util.flask - INFO - Passively logging in user aerotec from ::ffff:192.168.0.11
2021-03-06 17:48:46,247 - octoprint.access.users - INFO - Logged in user: aerotec
2021-03-06 17:48:46,438 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.0.11
2021-03-06 17:48:47,666 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.11
2021-03-06 17:48:47,711 - octoprint.server.util.flask - INFO - Passively logging in user aerotec from ::ffff:192.168.0.11
2021-03-06 17:48:47,712 - octoprint.access.users - INFO - Logged in user: aerotec
2021-03-06 17:48:51,300 - octoprint.server.util.sockjs - INFO - User aerotec logged in on the socket from client ::ffff:192.168.0.11
2021-03-06 17:48:57,390 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-03-06 17:48:57,424 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 0 port/baudrate candidates:
2021-03-06 17:48:57,424 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-03-06 17:48:57,426 - octoprint.util.comm - INFO - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-03-06 17:48:57,466 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-03-06 17:48:57,788 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_autodetect, payload: {'commerror_text': 'No more candidates to test, and no working port/baudrate combination detected.'}
2021-03-06 17:49:32,345 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-03-06 17:49:32,383 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 0 port/baudrate candidates:
2021-03-06 17:49:32,384 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-03-06 17:49:32,385 - octoprint.util.comm - INFO - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-03-06 17:49:32,421 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-03-06 17:49:32,797 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_autodetect, payload: {'commerror_text': 'No more candidates to test, and no working port/baudrate combination detected.'}
2021-03-06 17:50:03,399 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.12
2021-03-06 17:50:03,432 - octoprint.server.util.flask - INFO - Passively logging in user aerotec from ::ffff:192.168.0.12
2021-03-06 17:50:03,436 - octoprint.access.users - INFO - Logged in user: aerotec
2021-03-06 17:50:04,928 - octoprint.server.util.sockjs - INFO - User aerotec logged in on the socket from client ::ffff:192.168.0.12
2021-03-06 17:50:07,564 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-03-06 17:50:07,610 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 0 port/baudrate candidates:
2021-03-06 17:50:07,610 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-03-06 17:50:07,611 - octoprint.util.comm - INFO - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-03-06 17:50:07,654 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-03-06 17:50:07,925 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_autodetect, payload: {'commerror_text': 'No more candidates to test, and no working port/baudrate combination detected.'}
2021-03-06 17:50:10,094 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-03-06 17:50:10,128 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 0 port/baudrate candidates:
2021-03-06 17:50:10,128 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-03-06 17:50:10,130 - octoprint.util.comm - INFO - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-03-06 17:50:10,181 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-03-06 17:50:10,402 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_autodetect, payload: {'commerror_text': 'No more candidates to test, and no working port/baudrate combination detected.'}
2021-03-06 17:50:56,330 - octoprint.server.util.flask - INFO - Passively logging in user aerotec from ::ffff:192.168.0.12
2021-03-06 17:50:56,331 - octoprint.access.users - INFO - Logged in user: aerotec
2021-03-06 17:50:56,449 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.0.12
2021-03-06 17:50:57,177 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.12
2021-03-06 17:50:57,220 - octoprint.server.util.flask - INFO - Passively logging in user aerotec from ::ffff:192.168.0.12
2021-03-06 17:50:57,221 - octoprint.access.users - INFO - Logged in user: aerotec
2021-03-06 17:50:58,842 - octoprint.server.util.sockjs - INFO - User aerotec logged in on the socket from client ::ffff:192.168.0.12
2021-03-06 17:51:01,051 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-03-06 17:51:01,097 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 0 port/baudrate candidates:
2021-03-06 17:51:01,097 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-03-06 17:51:01,099 - octoprint.util.comm - INFO - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-03-06 17:51:01,156 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-03-06 17:51:01,390 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_autodetect, payload: {'commerror_text': 'No more candidates to test, and no working port/baudrate combination detected.'}
Serial Log:
2021-03-06 17:54:05,995 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
2021-03-06 17:58:29,720 - Enabling serial logging
2021-03-06 17:58:32,517 - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-03-06 17:58:32,565 - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-03-06 17:58:32,567 - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
OctoPrint 1.5.3
OctoPi 0.18.0
Creality CR10 V2
Firmware: Original firmware
Chrome Browser: 89.0.4389.82
Operating system: Windows 10
