Cant connect to default open port (:5000) the only way is to use haproxy
Cant access to the website using the default port :5000
Seems that the only way to access to the website is to used a haproxy -> opening a port and set backend to localhost:5000 (using the ip dont work)
OctoPrint 1.9
OctoPi 1.0.0
This has been the case for years on the OctoPi image, it's the expected behaviour.
You just need the IP, with no port, which means it will be using 80 and going through haproxy as intended.
