Greetings,
I have a slightly different issue. Well, my printer is connected to the network wirelessly through access point, since it is far from the main router. I can access it smoothly if my computer is connected by LAN, but not if using the wifi (on the main home router).
I even tried to ping the printer's IP with not luck, saying it was unreachable.
Is there a fix for this? any ideas?
Hey,
i have the same Problem as you. Did you get it to work over Wifi ?
@ibkhayyat @marten229, This thread is over one year old. I'm pretty sure that your WiFi environments are not identical to the original poster's nor are they identical to each other.
Please each of you open a new, separate topic in the Get Help category and fill out the template completely providing as much detail as possible about your individual WiFi environment including makes and models of routers, access points, etc.
Working like a charm, no modifications done
PuTTY is unstable though, manageable since I use it for specific things
