Router config - quite possibly
Different SSID's for two Wifi zones.
Country code - althought I'm in Ireland I'm using GB (also for keyboard). I believe Irish code is IE and I'll try that.
With LAN disconnected I can still ping octopi.local and not Putty SSH connect.
My octopi-wpa-supplicant.txt
# Use this file to configure your wifi connection(s).
# Just uncomment the lines prefixed with a single # of the configuration
# that matches your wifi setup and fill in SSID and passphrase.
# You can configure multiple wifi connections by adding more 'network'
# blocks.
# See https://linux.die.net/man/5/wpa_supplicant.conf
# (or 'man -s 5 wpa_supplicant.conf') for advanced options going beyond
# the examples provided below (e.g. various WPA Enterprise setups).
# !!!!! HEADS-UP WINDOWS USERS !!!!!
# Do not use Wordpad for editing this file, it will mangle it and your
# configuration won't work. Use a proper text editor instead.
# Recommended: Notepad++, VSCode, Atom, SublimeText.
# !!!!! HEADS-UP MACOSX USERS !!!!!
# If you use Textedit to edit this file make sure to use "plain text format"
# and "disable smart quotes" in "Textedit > Preferences", otherwise Textedit
# will use none-compatible characters and your network configuration won't
# work!
## WPA/WPA2 secured
network={
ssid="11716-Lightnet-WiFi"
psk="*********"
## Open/unsecured
#network={
# ssid="put SSID here"
# key_mgmt=NONE
## WEP "secured"
## WEP can be cracked within minutes. If your network is still relying on this
## encryption scheme you should seriously consider to update your network ASAP.
#network={
# key_mgmt=NONE
# wep_key0="put password here"
# wep_tx_keyidx=0
# Uncomment the country your Pi is in to activate Wifi in RaspberryPi 3 B+ and above
# For full list see: https://en.wikipedia.org/wiki/ISO_3166-1_alpha-2
#country=GB # United Kingdom
#country=CA # Canada
#country=DE # Germany
#country=FR # France
#country=US # United States
country=GB
### You should not have to change the lines below #####################
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
My OctoPrint.log
2020-03-11 16:05:29,744 - octoprint.startup - INFO - ******************************************************************************
2020-03-11 16:05:29,747 - octoprint.startup - INFO - Starting OctoPrint 1.4.0
2020-03-11 16:05:29,748 - octoprint.startup - INFO - ******************************************************************************
2020-03-11 16:05:30,457 - octoprint.startup - INFO - Unable to fetch plugin blacklist from https://plugins.octoprint.org/blacklist.json, proceeding without it: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /blacklist.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x74658990>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
2020-03-11 16:05:30,458 - octoprint.startup - INFO - Blacklist processing done
2020-03-11 16:05:30,532 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-03-11 16:05:32,157 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 27 hook handlers
2020-03-11 16:05:32,381 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-03-11 16:05:32,427 - octoprint.server - INFO - Intermediary server started
2020-03-11 16:05:32,429 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-03-11 16:05:32,550 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 27 hook handlers
2020-03-11 16:05:32,582 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-03-11 16:05:32,584 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-03-11 16:05:32,588 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2020-03-11 16:05:32,590 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2020-03-11 16:05:32,591 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2020-03-11 16:05:32,592 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2020-03-11 16:05:32,594 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2020-03-11 16:05:32,595 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2020-03-11 16:05:32,597 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2020-03-11 16:05:32,597 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-03-11 16:05:32,600 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-03-11 16:05:32,601 - octoprint.server - INFO - Added new permission from plugin printer_safety_check: PLUGIN_PRINTER_SAFETY_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_printer_safety_check_display')")
2020-03-11 16:05:32,602 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2020-03-11 16:05:32,603 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2020-03-11 16:05:32,658 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-03-11 16:05:33,988 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-03-11 16:05:34,953 - octoprint.util.pip - INFO - Version of pip is 19.3.1
2020-03-11 16:05:34,955 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-03-11 16:05:34,956 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-03-11 16:05:34,961 - octoprint.plugin.core - INFO - Initialized 15 plugin implementation(s)
2020-03-11 16:05:34,971 - octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
| Login UI (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/loginui
2020-03-11 16:05:34,989 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 917016576
| os:
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 3 Model B Plus Rev 1.3
| octopi_version: 0.17.0
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
2020-03-11 16:05:34,999 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-03-11 16:05:35,018 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-03-11 16:05:35,950 - octoprint.server - INFO - Shutting down intermediary server...
2020-03-11 16:05:35,994 - octoprint.server - INFO - Intermediary server shut down
2020-03-11 16:05:35,997 - octoprint.events - INFO - Processing startup event, this is our first event
2020-03-11 16:05:35,999 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2020-03-11 16:05:36,001 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-03-11 16:05:36,004 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-03-11 16:05:36,006 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-03-11 16:05:36,007 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-03-11 16:05:36,021 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2020-03-11 16:05:36,033 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2020-03-11 16:05:36,043 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2020-03-11 16:05:36,060 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2020-03-11 16:05:36,147 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-03-11 16:05:37,141 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-03-11 16:05:37,149 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-03-11 16:05:37,152 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-03-11 16:05:37,162 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.178.21
2020-03-11 16:05:37,527 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.178.21
2020-03-11 16:05:37,691 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-03-11 16:05:37,738 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.178.25/'}
2020-03-11 16:05:37,772 - octoprint.server.util.flask - INFO - Passively logging in user towlerg from ::ffff:192.168.178.21
2020-03-11 16:05:37,775 - octoprint.access.users - INFO - Logged in user: towlerg
2020-03-11 16:05:37,803 - octoprint.server.util.flask - INFO - Passively logging in user towlerg from ::ffff:192.168.178.21
2020-03-11 16:05:37,805 - octoprint.access.users - INFO - Logged in user: towlerg
2020-03-11 16:05:37,825 - octoprint.server.util.sockjs - INFO - User towlerg logged in on the socket from client ::ffff:192.168.178.21
2020-03-11 16:05:38,307 - octoprint.server.util.sockjs - INFO - User towlerg logged in on the socket from client ::ffff:192.168.178.21
2020-03-11 16:05:45,477 - octoprint.server.preemptive_cache - INFO - ... done in 7.74s
2020-03-11 16:05:45,478 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://octopi.local/'}
2020-03-11 16:05:47,266 - octoprint.server.preemptive_cache - INFO - ... done in 1.79s
2020-03-11 16:06:13,795 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.178.21
