What is the problem? Cant connect to octoprint remotely when accessing via OpenVPN connection
What did you already try to solve it? Screen comes up saying 'Connecting to Octoprint server' but it never loads so im a bit stuck! Tried to connect with android phone and laptop remotely configured as clients.
Logs (syslog, dmesg, ... no logs, no support) No logs available as im assuming its a setting ive missed somewhere!
EDIT: Just found this in the logs when i tried to connect again:
2020-07-02 19:34:10,656 - octoprint.server.util.flask - INFO - Passively logging in user dansharpy from ::ffff:10.8.0.6
2020-07-02 19:34:10,657 - octoprint.access.users - INFO - Logged in user: dansharpy
2020-07-02 19:34:12,187 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:10.8.0.6
Additional information about your network (Hardware you are trying to connect to, hardware you are trying to connect from, router, access point, used operating systems, ...) TP Link Archer VR900 router with Open VPN configured. Octoprint on raspberry pi4 2gb. Static IP for router and Octoprint. Can access via octopi.local and ip when within network no problem. Can also access pi over ssh when on VPN connection. Help!
Also id just like to say thank you to everyone involved with Octoprint. Ive only had my printer for about a month and had Octoprint hooked up since day 1 and im loving it!
