As of today when I started the printer it seems it cannot connect to my printer anymore. (connect button does nothing)
Tried to connect to the printer directly via ssh and "sudo screen /dev/ttyUSB0 115200" and that is working (at least I can send commands like G28 and the printer responds).
Manually selected the connection in OctoPrint to /dev/ttyUSB0 and 115200 baud rate.
I tried safe mode but that did unfortunately not fix the problem.
Complete Logs
octoprint.log:
2020-12-13 11:44:14,424 - octoprint.startup - INFO - ******************************************************************************
2020-12-13 11:44:14,426 - octoprint.startup - INFO - Starting OctoPrint 1.5.2
2020-12-13 11:44:14,426 - octoprint.startup - INFO - ******************************************************************************
2020-12-13 11:44:14,877 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2020-12-13 11:44:14,998 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2020-12-13 11:44:14,998 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:53 is working
2020-12-13 11:44:14,999 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2020-12-13 11:44:15,009 - octoprint.startup - INFO - Blacklist processing done, adding 12 blacklisted plugin versions: roomtemp (any), GcodeEditor (0.1.1), GcodeEditor (0.2.0), GcodeEditor (0.2.1), GcodeEditor (0.2.2), GcodeEditor (0.2.3), GcodeEditor (0.2.4), GcodeEditor (0.2.5), GcodeEditor (0.2.6), GcodeEditor (0.2.8), gcodeleveling (0.1.0), gcodeleveling (0.1.1)
2020-12-13 11:44:15,029 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-12-13 11:44:15,915 - octoprint.plugin.core - INFO - Plugin Exclude Region (0.3.0) is disabled.
2020-12-13 11:44:16,058 - octoprint.plugin.core - INFO - Plugin Octolapse (0.4.0) is disabled.
2020-12-13 11:44:16,293 - octoprint.plugin.core - INFO - Found 32 plugin(s) providing 30 mixin implementations, 60 hook handlers
2020-12-13 11:44:16,529 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-12-13 11:44:16,543 - octoprint.server - INFO - Intermediary server started
2020-12-13 11:44:16,561 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-12-13 11:44:16,865 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-12-13 11:44:16,868 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: u"Need(method='role', value=u'plugin_action_command_notification_show')")
2020-12-13 11:44:16,869 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: u"Need(method='role', value=u'plugin_action_command_notification_clear')")
2020-12-13 11:44:16,870 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2020-12-13 11:44:16,871 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2020-12-13 11:44:16,872 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2020-12-13 11:44:16,873 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2020-12-13 11:44:16,874 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2020-12-13 11:44:16,875 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_firmware_check_display')")
2020-12-13 11:44:16,876 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2020-12-13 11:44:16,878 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2020-12-13 11:44:16,879 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-12-13 11:44:16,881 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-12-13 11:44:16,882 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2020-12-13 11:44:16,883 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2020-12-13 11:44:16,884 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: u"Need(method='role', value=u'plugin_softwareupdate_configure')")
2020-12-13 11:44:16,898 - octoprint.printer.standard - INFO - Using print time estimator provided by PrintTimeGenius
2020-12-13 11:44:17,142 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-12-13 11:44:17,821 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-12-13 11:44:18,415 - octoprint.util.pip - INFO - Version of pip is 19.3.1
2020-12-13 11:44:18,417 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-12-13 11:44:18,417 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-12-13 11:44:18,423 - octoprint.plugin.core - INFO - Initialized 30 plugin implementation(s)
2020-12-13 11:44:18,452 - octoprint.plugin.core - INFO - 32 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_notification
| Bed Visualizer (1.0.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_bedlevelvisualizer
| BetterHeaterTimeout (1.3.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_BetterHeaterTimeout
| Cura Thumbnails (0.2.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_ultimakerformatpackage
| DiscordRemote (2.64.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_discordremote
| !Exclude Region (0.3.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_excluderegion
| File Check (2020.8.7) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_file_check
| FileManager (0.1.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_filemanager
| Firmware Check (2020.9.23) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmware_check
| Fullscreen Plugin (0.0.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_fullscreen
| GCode Viewer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/gcodeviewer
| GcodeEditor (0.2.10) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_GcodeEditor
| Navbar Temperature Plugin (0.14) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_navbartemp
| !Octolapse (0.4.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octolapse
| OctoPod Plugin (0.2.9) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octopod
| PrintTimeGenius Plugin (2.2.7) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_PrintTimeGenius
| Resource Monitor (0.2.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_resource_monitor
| Terminal Commands Extended (0.1.7rc2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_terminalcommandsextended
| UI Customizer (0.1.1.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_uicustomizer
2020-12-13 11:44:18,484 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1500.0
| ram: 4041732096
| os:
| bits: 32
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 4 Model B Rev 1.2
| octopi_version: 0.17.0
| throttle_state: '0x0'
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
2020-12-13 11:44:18,500 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-12-13 11:44:18,525 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-12-13 11:44:19,223 - octoprint.server - INFO - Shutting down intermediary server...
2020-12-13 11:44:19,267 - octoprint.server - INFO - Intermediary server shut down
2020-12-13 11:44:19,269 - octoprint.events - INFO - Processing startup event, this is our first event
2020-12-13 11:44:19,269 - octoprint.events - INFO - Adding 2 events to queue that were held back before startup event
2020-12-13 11:44:19,272 - octoprint.plugins.discordremote - INFO - Received event: startup
2020-12-13 11:44:19,276 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-12-13 11:44:19,277 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2020-12-13 11:44:19,327 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-12-13 11:44:19,339 - octoprint.server - INFO - Trying to connect to configured serial port /dev/ttyUSB0
2020-12-13 11:44:19,380 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-12-13 11:44:19,383 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-12-13 11:44:19,595 - octoprint.plugins.discordremote - ERROR - Failed to send message
2020-12-13 11:44:19,606 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2020-12-13 11:44:19,638 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-12-13 11:44:20,076 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {u'throttled_mask': 0, u'throttled_voltage_now': False, u'throttled_voltage_past': False, u'throttled_overheat_now': False, u'throttled_now': False, u'throttled_past': False, u'throttled_overheat_past': False}
2020-12-13 11:44:20,224 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._http._tcp.local.' for _http._tcp.local.
2020-12-13 11:44:20,752 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-12-13 11:44:21,036 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._octoprint._tcp.local.' for _octoprint._tcp.local.
2020-12-13 11:44:21,040 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2020-12-13 11:44:21,084 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2020-12-13 11:44:21,313 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.18
2020-12-13 11:44:21,305 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-12-13 11:44:21,908 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-12-13 11:44:21,992 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-12-13 11:44:22,001 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-12-13 11:44:22,178 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 24.8GB. That is considered sufficient for updating.
2020-12-13 11:44:22,376 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-12-13 11:44:22,490 - octoprint.server.util.flask - INFO - Passively logging in user pontus from ::ffff:192.168.1.18
2020-12-13 11:44:22,491 - octoprint.access.users - INFO - Logged in user: pontus
2020-12-13 11:44:22,522 - octoprint.server.util.sockjs - INFO - User pontus logged in on the socket from client ::ffff:192.168.1.18
2020-12-13 11:44:22,557 - octoprint.plugins.bedlevelvisualizer - INFO - OctoPrint-BedLevelVisualizer loaded!
2020-12-13 11:44:22,563 - octoprint.plugins.discordremote - INFO - DiscordRemote is started !
2020-12-13 11:44:22,566 - octoprint.plugins.discordremote - INFO - Starting Presence thread
2020-12-13 11:44:22,578 - octoprint.plugins.octopod - INFO - OctoPod loaded!
2020-12-13 11:44:22,606 - octoprint.plugins.uicustomizer - INFO - UI Customizer is initialized.
2020-12-13 11:44:22,833 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 7}
2020-12-13 11:44:22,861 - octoprint.plugins.discordremote - INFO - Socket URL is wss://gateway.discord.gg
2020-12-13 11:44:23,004 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.1.190/'}
2020-12-13 11:44:23,050 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {u'python': '2.7.16', u'os': u'linux', u'ram': 4041732096L, u'octopi_version': u'0.17.0', u'version': u'1.5.2', u'plugins': u'betterheatertimeout:1.3.0,gcodeeditor:0.2.10,fullscreen:0.0.6,octopod:0.2.9,resource_monitor:0.2.6,filemanager:0.1.4,uicustomizer:0.1.1.2,terminalcommandsextended:0.1.7rc2,bedlevelvisualizer:1.0.0,ultimakerformatpackage:0.2.1,navbartemp:0.14,discordremote:2.64.0,printtimegenius:2.2.7', u'pip': '19.3.1', u'cores': 4, u'freq': 1500.0, u'pi_model': u'Raspberry Pi 4 Model B Rev 1.2', u'bits': 32}
2020-12-13 11:44:23,227 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {u'python': '2.7.16', u'os': u'linux', u'ram': 4041732096L, u'octopi_version': u'0.17.0', u'version': u'1.5.2', u'pip': '19.3.1', u'cores': 4, u'freq': 1500.0, u'pi_model': u'Raspberry Pi 4 Model B Rev 1.2', u'bits': 32}
2020-12-13 11:44:23,321 - octoprint.plugins.discordremote - INFO - Received HELLO message
2020-12-13 11:44:23,326 - octoprint.plugins.discordremote - INFO - Sending IDENTIFY message
2020-12-13 11:44:23,343 - octoprint.plugins.discordremote - INFO - Heartbeat thread: None
2020-12-13 11:44:23,354 - octoprint.plugins.discordremote - INFO - Starting Heartbeat thread
2020-12-13 11:44:23,375 - octoprint.plugins.discordremote - INFO - Heartbeat: {"d": null, "op": 1}
2020-12-13 11:44:23,781 - octoprint.plugins.discordremote - INFO - Received HEARTBEAT_ACK message
2020-12-13 11:44:23,794 - octoprint.plugins.discordremote - INFO - Received READY message
2020-12-13 11:44:33,008 - octoprint.plugins.discordremote - INFO - Presence: {"d": {"status": "online", "activities": [{"type": 0, "name": "Not operational."}], "since": null, "afk": false}, "op": 3}
2020-12-13 11:44:34,344 - octoprint.server.util.flask - INFO - Passively logging in user pontus from ::ffff:192.168.1.18
2020-12-13 11:44:34,345 - octoprint.access.users - INFO - Logged in user: pontus
2020-12-13 11:44:34,428 - octoprint.server.preemptive_cache - INFO - ... done in 11.42s
2020-12-13 11:44:35,040 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.18
2020-12-13 11:44:35,939 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.18
2020-12-13 11:44:36,048 - octoprint.server.util.flask - INFO - Passively logging in user pontus from ::ffff:192.168.1.18
2020-12-13 11:44:36,048 - octoprint.access.users - INFO - Logged in user: pontus
2020-12-13 11:44:38,298 - octoprint - ERROR - Exception on /api/printer/command/custom [GET]
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 2447, in wsgi_app
response = self.full_dispatch_request()
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1952, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1821, in handle_user_exception
reraise(exc_type, exc_value, tb)
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1950, in full_dispatch_request
rv = self.dispatch_request()
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1936, in dispatch_request
return self.view_functions[rule.endpoint](**req.view_args)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/util/flask.py", line 1539, in decorated_view
return func(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/vendor/flask_principal.py", line 199, in _decorated
rv = f(*args, **kw)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/api/printer.py", line 481, in getCustomControls
customControls = settings().get(["controls"])
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/settings.py", line 1781, in get
result = process()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/settings.py", line 1775, in process
return self._get_value(path, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/settings.py", line 1736, in _get_value
value = preprocessor(value)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/settings.py", line 896, in _process_custom_controls
return list(map(process_control, controls))
TypeError: argument 2 to map() must support iteration
2020-12-13 11:44:38,304 - tornado.access - ERROR - 500 GET /api/printer/command/custom (::ffff:192.168.1.18) 11.87ms
2020-12-13 11:44:38,644 - octoprint.server.util.sockjs - INFO - User pontus logged in on the socket from client ::ffff:192.168.1.18
2020-12-13 11:44:43,080 - octoprint.plugins.discordremote - INFO - Presence: {"d": {"status": "online", "activities": [{"type": 0, "name": "/help"}], "since": null, "afk": false}, "op": 3}
2020-12-13 11:44:53,095 - octoprint.plugins.discordremote - INFO - Presence: {"d": {"status": "online", "activities": [{"type": 0, "name": "Not operational."}], "since": null, "afk": false}, "op": 3}
OctoPrint 1.5.2
OctoPi 0.17.0
Ender 3 V2 (latest Marlin from marlin.crc.id.au)
RPi 4
I bet I did something stupid yesterday but I cannot figure out what it might've been, at least I know I did not update the firmware.
