I've recently updated to 1.7.0rc2, every thing was fine after the initial reboot, however after installing a new Plugin (Plotly Temp Graph) and restarting, I was greeted with the following error
State: Offline after error
No more candidates to test, and no working port/baudrate combination detected.
This is what I've done so far
- Disabled the plugin, with no affect
- Booted into safe mode with no affect
- Tested the printer with the same cable on another pc, I can see the device appearing (not tested printing).
- Connected to octopi on the cli, the following is appearing in the journal.
Aug 24 12:04:55 octopi kernel: usb 1-1.5: new full-speed USB device number 7 using dwc_otg
Aug 24 12:04:55 octopi kernel: usb 1-1.5: New USB device found, idVendor=2c99, idProduct=0002, bcdDevice= 1.30
Aug 24 12:04:55 octopi kernel: usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 24 12:04:55 octopi kernel: usb 1-1.5: Product: Original Prusa i3 MK3
Aug 24 12:04:55 octopi kernel: usb 1-1.5: Manufacturer: Prusa Research (prusa3d.com)
Aug 24 12:04:55 octopi kernel: usb 1-1.5: SerialNumber: CZPX0119X004XK02248
Aug 24 12:04:55 octopi kernel: cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
Aug 24 12:04:55 octopi mtp-probe[920]: checking bus 1, device 7: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5"
Aug 24 12:04:55 octopi mtp-probe[920]: bus: 1, device: 7 was not an MTP device
Aug 24 12:04:55 octopi mtp-probe[922]: checking bus 1, device 7: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5"
Aug 24 12:04:55 octopi mtp-probe[922]: bus: 1, device: 7 was not an MTP device
no
octoprint-systeminfo-20210824121319.zip (73.4 KB)
browser.user_agent : Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:91.0) Gecko/20100101 Firefox/91.0
connectivity.connection_check : 1.1.1.1:53
connectivity.connection_ok : true
connectivity.enabled : true
connectivity.online : true
connectivity.resolution_check : octoprint.org
connectivity.resolution_ok : true
env.hardware.cores : 4
env.hardware.freq : 900
env.hardware.ram : 916791296
env.os.bits : 32
env.os.id : linux
env.os.platform : linux
env.plugins.pi_support.model : Raspberry Pi 2 Model B Rev 1.1
env.plugins.pi_support.octopi_version : 0.17.0
env.plugins.pi_support.throttle_state : 0x0
env.python.pip : 20.2.3
env.python.version : 3.7.3
env.python.virtualenv : true
octoprint.safe_mode : true
octoprint.version : 1.7.0rc2
systeminfo.generator : systemapi
