Cant connect to server
I cant connect to octoprint when I run it from octi4a
Reboot the server, turn on and off all extensions
Yes, Twice
Cant get bundle because I cant open up server
Printer is Kobra 2
Running octiprint for android
hello there so have you tried to SSH into your raspberry?
or can you SSH but not get into the server?
have you tried all the links?
http://raspberrypi.local
or does it not work anyway?
Please do not dig out old threads.
You already have your own threads open on that topic.
thought it was from this year haha sorry
