Can't connect to two Ender 3's over USB at the same time
I have four printers, two mendelmax printers and two Ender 3s with stock firmware. I have two octoprints setup on a PC for the two mendel max printers and can print from both at the same time, they connect to /dev/ttyACM0 and /dev/ttyACM1. When I plug the two Enders in they connect to /dev/ttyUSB0 and /dev/ttyUSB1 but I can only connect to one at a time. If I connect to printer 1, then open my second octoprint and it refuses to connect, same happens when I switch.
Anyone have any idea why that is? Is there something about the Ender boards that conflict with each other over USB so you can't connect to two from the same computer?
On the second connection it seems to receive a bunch of temperature data before shutting down - not sure which printer is giving that info. Here is the log:
Connecting to: /dev/ttyUSB1
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial<id=0x7f9708768510, open=True>(port='/dev/ttyUSB1', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
Send: N0 M110 N0*125
Recv: o
Recv: :20.62 /0.00 B:20.62 /0.00 @:0B@T:20.62 /0.00 B:20.62 /0.00 @:0 B@:0
Recv: B@:0
Recv: T:20.62 /0.00 B:20.62 /0.00 @:0 B@:0
[... snipped ...]
Recv: T:20.62 /0.00 B:20.51 /0.00 @:0 B@:0
Unexpected error while reading serial port, please consult octoprint.log for details: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2605
Please see https://faq.octoprint.org/serialerror for possible reasons of this.
Changing monitoring state from "Connecting" to "Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2605)"
I'm using Octoprint Version 1.3.10.
