Can't connect to wifi without specific commands
My octopi on start cant(or doesnt) connect to my wifi, however, after killing wpa_supplicant, deleting the socket file and starting wpa_supplicant again everything works.
I am quite a noob with raspberry pi's, terminals and commands. At first i didnt even know why i couldnt connect to the UI and now i think this is the farthest i can go ( i dont know where to start or what to do)
I dont know
Sorry i dont know what to put here
Yes so as i said im a noob. After a new flash there was no ( or i couldnt find) a wpa_supplicant.conf file, so i created one. I checked and everything in it should be alright (i can connect to the internet afterall). Also one interesting thing is that when i tried to ssh into the pi from my pc via ethernet(now i have a monitor and keyboard plugged in) i would get randomly disconnected (even without doing anything).
I am trying to connect to the internet wirelessly (no ethernet)
I am using a raspberry pi 4b with the intended power supply.
I use the raspberry pi imager (and the octoprint version in it) octoprint version 1.11.2, octopi version 1.1.0
To get the wifi running i use these commands:
1)sudo killall wpa_supplicant
2)sudo rm -rf /var/run/wpa_supplicant/*
3)sudo wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
4) sudo dhclient wlan0
If i reboot the pi all files are there but i need to repeat those commands to get my pi to connect.
If anyone is willing to help me and needs more information please tell me and thanks in advance!
(I used chat gpt for most of my work so please talk in simple terms....)
OctoPi 1.1.0 is based on Debian 12 (bookworm). WiFi configuration switched from wpa_supplicant to NetworkManager. See https://forums.raspberrypi.com/viewtopic.php?t=357623.
I have also read that while the RPi Imager 1.9.4 has problems, the 1.8.5 Imager was supposed to work but when I tried it, the image written by both failed to connect to WiFi. I was able to fix the image using the instructions in this thread.
If you have a monitor connected to your RPi, there are a few reboots involved in the initial boot.
I was able to get 1.8.5 to work again by clearing the customization settings and entering them again. I set the WiFi country by scrolling through the (huge) dropdown list and selecting US.
Previously, I have been typing US into the dropdown so I'm not sure yet which action fixed the extra return in firstrun.sh.
Thank you very much! Problem fixed
