yes! >> "Sandro@octopi.local: Permission denied (publickey,password)."
I also tried with an newly generated API-key and with an IP-adress like 192.168...
OctoPrint's login info is not the same as the OS login. The API key in OctoPrint won't let you in to the system.
On an OctoPi install, the username is pi and the password is raspberry unless you previously logged in and changed it, it's not the same password as you use to login to the web UI.
nmap kiwi.intern
Starting Nmap 7.92 ( https://nmap.org ) at 2021-11-21 00:40 CET
Nmap scan report for kiwi.intern (192.168.23.18)
Host is up (0.0013s latency).
Other addresses for kiwi.intern (not scanned): fded::cafe:18
Not shown: 995 closed tcp ports (reset)
PORT STATE SERVICE
22/tcp open ssh
80/tcp open http
139/tcp open netbios-ssn
443/tcp open https
445/tcp open microsoft-ds
MAC Address: B8:27:EB:3F:66:A1 (Raspberry Pi Foundation)
Nmap done: 1 IP address (1 host up) scanned in 0.25 seconds
No port 20, 21. FTP is so 1990
(Ok, I read it up, an extended version of scp goes by the moniker SFTP. When you can ssh into a box scp works as well. You can always test it from the terminal on OSX and test if its a limitation of that other program)
