I got a BBB with a replicape rev b. I can connect to it via kamikaze.local and see the octoprint dashboard.
I configured my printer via this dashboard after which i wanted to test the printer.
However, I can't control anything via this dashboard. The arrows for control are grayed out and the terminal/log window is also grayed out + a 'block' sign on mouse hoover.
I don't quite understand why this is happening since it should be able to be controlled via ethernet only. In the upper left octoprint claims my printer is offline and I can see a Uart connection setup (which obviously doesn't connect).
I'm guessing I missed something in config to configure control via ethernet but I can't seem to find it. Anyone else knows how to fix this? Thanks!
