**cant find printer did everything in the forum didnt find anything that works also install plugin (Malyan/Monoprice Connection Fix (0.1.3) error message ( Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
Failed to autodetect serial port, please set it manually.)
unfortunately there is no usb connection to the printer detected.
If I understand the printer description correctly it already got a Pi zero connected.
Did you connect your Pi 2 to the Pi zero or directly to the printers mainboard?
