Logitech C270 and C922
I can't get a 2nd camera working. The C922 comes up fine but I can't connect to the C270
**I've followed the YouTube video by Chris's Basement OctoPi - Multiple Camera Setup - Raspberry Pi Camera - Chris's Basement - 2023 - YouTube **
Here is the webcamd file from the System bundle. Please advise if you need the other files as well
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly set USB device:
Found video devices:
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video31
config file='/boot/octopi.txt':USB device was not set in options, starting MJPG-streamer with the first found video device: /dev/video10
<13>Sep 21 20:24:14 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video10
MJPG Streamer Version.: 2.0
i: Using V4L2 device.: /dev/video10
i: Frames Per Second.: 10
i: Format............: JPEG
Error opening device /dev/video10: video capture not supported.
i: init_VideoIn failed
Done bringing up all configured video devices
Scanning again in two minutes
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video31
<13>Mar 27 09:07:08 root: Starting USB webcam
Checking for VL805 (Raspberry Pi 4)... - It seems that you don't have VL805 (Raspberry Pi 4).
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video31
<13>Mar 27 09:09:09 root: Starting USB webcam
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video31
<13>Mar 27 09:11:10 root: Starting USB webcam
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video31
<13>Mar 27 09:13:11 root: Starting USB webcam
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video31
<13>Mar 27 09:15:12 root: Starting USB webcam
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video31
<13>Mar 27 09:17:13 root: Starting USB webcam
camera: auto
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video2
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video3
/dev/video31
config file='/boot/octopi.txt':USB device was not set in options, starting MJPG-streamer with the first found video device: /dev/video0
<13>Mar 27 09:17:05 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
o: HTTP Listen Address..: 127.0.0.1
Goodbye...
camera: auto
cfg_file: /boot/octopi.conf.d/webcam2.txt
camera: usb
usb options: -r 640x480 -f 10 -d /dev/v4l/by-id/usb-046d_C270_HD_WEBCAM_04E57C60-video-index0
http options: -w ./www-octopi -n -p 8081
Explicitly set USB device: /dev/v4l/by-id/usb-046d_C270_HD_WEBCAM_04E57C60-video-index0
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video2
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video3
/dev/video31
config file='/boot/octopi.conf.d/webcam2.txt':Video device already in use.
<13>Mar 27 09:42:49 root: Starting USB webcam
Goodbye...
camera: auto
camera: usb
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video2
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video3
/dev/video31
<13>Mar 27 10:21:47 root: Starting USB webcam
I'm using a powered USB hub and the latest stable version of Octopi.
Thanks in advance for any help you can provide!
