Cant get cheap webcam to work with octoprint
https://m.myvipon.com/#/product/8490438?sl=e53166c23c45ad2790e27c39934881e6
Ordered this webcam because said they verified it worked with Octoprint but can't seem to get it to work. tried different resolutions still nothing any help is much appreciated
octopi version 0.18.0
octoprint version 1.6.1
fresh octoprint install
webcam log
cfg_file: /boot/octopi.txt
camera: usb
usb options: -r 1920x1080 -f 30
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Dec 2 12:56:09 root: Starting USB webcam
  • It seems that you don't have VL805 (Raspberry Pi 4).
    Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 1920x1080 -f 30 -d /dev/video0
    i: Desired Resolution: 1920 x 1080
    i: Frames Per Second.: 30
    i: Format............: JPEG
    o: HTTP Listen Address..: 127.0.0.1
Goodbye...
i: select() timeout
i: cleaning up resources allocated by input thread
Starting up webcamDaemon...
format outputv4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'MJPG' (Motion-JPEG, compressed)
		Interval: Discrete 0.033s (30.000 fps)
		Interval: Discrete 0.040s (25.000 fps)
	Size: Discrete 1920x1080
[1]: 'H264' (H.264, compressed)
[2]: 'YUYV' (YUYV 4:2:2)
