What is the problem? not work octoprint on windows
(venv) C:\OctoPrint>octoprint serve
2020-01-20 21:29:35,480 - octoprint.startup - INFO - ******************************************************************************
2020-01-20 21:29:35,496 - octoprint.startup - INFO - Starting OctoPrint 1.3.12
2020-01-20 21:29:35,496 - octoprint.startup - INFO - ******************************************************************************
2020-01-20 21:29:37,683 - octoprint.startup - CRITICAL - Could not initialize plugin manager: 'ascii' codec can't decode byte 0xdc in position 77: ordinal not in range(128)
There was a fatal error starting up OctoPrint.
2020-01-20 21:29:37,683 - octoprint.startup - CRITICAL - There was a fatal error starting up OctoPrint.
Try to start OctoPrint in Safe Mode. Click the link to see how to do this.
Sorry, it doesn't work
how else can work
(venv) C:\OctoPrint>octoprint serve --safe
2020-01-20 22:15:24,983 - octoprint.startup - INFO - ******************************************************************************
2020-01-20 22:15:24,983 - octoprint.startup - INFO - Starting OctoPrint 1.3.12
2020-01-20 22:15:24,983 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2020-01-20 22:15:24,983 - octoprint.startup - INFO - Reason for safe mode: command line flag
2020-01-20 22:15:26,108 - octoprint.startup - CRITICAL - Could not initialize plugin manager: 'ascii' codec can't decode byte 0xdc in position 77: ordinal not in range(128)
2Could not initialize plugin manager: 'ascii' codec can't decode byte 0xdc in position 77: ordinal not in range(128)
020-01-20 22:15:26,108 - octoprint.startup - CRITICAL - There was a fatal error starting up OctoPrint.
It seems that the OctoPi/OctoPrint installation has a failure.
Best is to restart by burning the image to the SD card again.
If it does not work then, maybe the SD card is faulty.
@Ewald_Ikemann, you missed a detail.
@Hasan_Basri_TURKMEN What version of Python do you use?
1.3.12 octoprint for windows
I am using Phyton 2.7.14
