Can't get Plugin to Install
I cannot get the Ender3v2tempfix plugin to install on my Raspberry Pi 4.
I have tried to install it both in the command line and via URL, but with no success. I keep getting a "Command "python setup.py egg_info" failed with error code 255 in /tmp/pip-req-build-0kpq5P" error.
Complete Logs
I don't think this is a loggable issue by OctoPrint
Latest OctoPi version, Ender 5 Pro, Rasbian
Thanks for your help!
Hello @Redwood74
You mean this one?
So please do it.
Are you so sure? There is also a plugin_pluginmanager_console.log
1.4.2 or 1.5.0rc3?
Or alternatively, 0.17 or 0.18rc... this is why people have to be specific...
I was able to get it to install through the printer interface instead of the command line. Thanks!
OctoPrint plugins usually are meant to be installed via the plugin manager of OctoPrint. :face_with_raised_eyebrow:
:smiley: Trying to get too cute as I learn Python
I see. Could you please:
