Can't get system bundle and server not starting
The OctoPrint server is currently not running (therefore I cannot get to the menu)
==> none of the fixes work for this
I cannot get the System Bundle:
mike650@Octoprint:~ $ ~/octoprint/bin/octoprint systeminfo .
-bash: /home/mike650/octoprint/bin/octoprint: No such file or directory
It worked a year ago with an older Octoprint (version 8), running on a Raspberry Pi W
I now tried that older version and it would not accept password
Got the password problem and then it said I must update to version 11. The update never completed. Kept on saying "Still running"
So I downloaded a completely new system and I am back to the " The OctoPrint server is currently not running" problem. None of the fixes I have found for this will work.
I get errors when I try to get System Bundle.
Not able to access the Log
I can access the Pi using SSH (via Putty)
I changed user from pi to mike650
tried everything I found from searching the internet
No - not sure how
couldn't try SAFE MODE
All my efforts to get System Bundle have failed: Illegal instructions ...or File / directory Not Found.
Browser: Chrome on Windows 11
Printer: Monoprice Maker Select 3D Printer V2
Versions:
OctoPrint: 1.11.5
OctoPi: 1.1.0
Are you still attempting to use a "Raspberry Pi W"? I assume this is a "Raspberry Pi Zero W".
What image (and imager) did you use? Specific version numbers, please.
Hopefully you kept the old microSD card and flashed a new microSD card. It is possible to recover (change) the password.
I strongly recommend leaving the username as "pi". You can (and should) use your own password.
The RPi Zero W is not recommended as it is underpowered. However, an RPi Zero 2 W is capable of running OctoPi / OctoPrint.
Did you remove the pinuser andni sert the "mike650" for the username? If so, that is your issue. Octoprint requires the pi user
