What is the problem? - So I wasn't turning the printer on for 13 days now (I'm a student didn't have the time lol) and yesterday I finally want to print something and suddenly after I turned on the printer and the pi, It shows in my network mesh app that is offline even it on and it worked great before 12 days ago.
the pi show sings that it working, the LEDs are on
What did you already try to solve it? I already tried to turn off the pi and the printer and unplug it from the printer (USB), and then turn first the printer and then the pi and then plug the USB cable, I tried also to connect it directly to one of the mesh routers
I tried also to load the Sd card into my computer to see if it failed or something, and it looks just fine with all the settings of the network that I set when I installed it (a year ago)
Logs (syslog, dmesg, ... no logs, no support) when I connect by the http://octopi.local or by OctoEveryWhere both it will not let me, with the domain it say "can't access to the website" and OctoEveryWhere says it offline.
and like I said in the mesh network app it shows as offline (not blocked or something)
Additional information about your network (Hardware you are trying to connect to, the hardware you are trying to connect from, router, access point, used operating systems, ...)
As I said, I have a mesh network system (Tp-Link Deco if it matters), and everything working normal, I tried to unplug the main router from the wall to reset it up
